For Call of duty Mobile Players , fix craches . via OnePlus 6
  1. Z1567506711805
    Froyo Jan 28, 2020
    Z1567506711805 , via OnePlus 6 , Jan 28, 2020 :
    Hello players, I tried a lot and did not find a solution to this problem, and I updated the screen card for the beta and nothing happened, I also tried custom rom and the problem was not solved ..
    The only solution that I can tell you is that when the game starts in Waiting hall - Lobby - before the start plane. Go to Recent apps , and close the game just from recent apps and then open it again. You will be asked whether you want to return to the game and click Yes, so you will be able to play with full FPS AND GRAPHIC , With Zero issues or craches
    this worked for me after Many and many of try everything to stop craches, but note.. i tried this on season 3 update on pixel custom rom from xda forums , pls try it on oxygen and tell me what happen
    ask for my id on PM and lets play
    waiting .
