forget Patten lock via OnePlus 6
  1. G_Jagdish_Jain_APqq
    Cupcake Dec 12, 2019
  2. G_Jagdish_Jain_APqq
  3. Horsault
    Marshmallow Moderator Dec 12, 2019
    Horsault , Dec 12, 2019 :
    Use any other unlocking way you also set up (like PIN code or fingerprint).
    Unfortunately, for safety reasons, your storage is encrypted, and your phone protected.
    If there was a possibility to bypass all securities, especially communicated on a public forum, then your device wouldn't be safe any longer, would it?
    Scherpenseel and G_plusone like this.
  4. G_Jagdish_Jain_APqq
    G_Jagdish_Jain_APqq , via OnePlus 6 , Dec 12, 2019 :
    My one plus 3t device has got pattern locked.
    please help me out. I don't want to loose my data. it's too important.
    Do help me out without loosing my data, I want to unlock my phone.
    please help me out please [e]1f62d[/e][e]1f62d[/e][e]1f62d[/e][e]1f62d[/e]
  5. Bartnl
    Lollipop Dec 12, 2019
    Bartnl , Dec 12, 2019 :
    The pattern lock does not pop up out of it's own, without setting it up first.
    So you must have set it yourself with a pattern.
  6. Horsault
    Duplicate thread merged.
    Read forum rules.
  7. G_Jagdish_Jain_APqq
    I remember by old pattern but it got changed by itself into some other pattern.
    And I had shut down my one plus device 3T and have only 1 attempt to try pattern.
    And even don't know how to get out of this mess.
    please help me out, I beg you.
    I am obsessed with such high security[e]1f62d[/e][e]1f62d[/e][e]1f62d[/e][e]1f62d[/e]
  8. Cervantes
    Lollipop Moderator Dec 12, 2019
    Cervantes , Dec 12, 2019 :
    You are obsessed with security
    You must use a password that is easy to remember for You
    I have a book with my passwords
  9. Horsault
  10. G_Jagdish_Jain_APqq
  11. Cervantes
    You can try google search: reset forgotten pattern
  12. G_Jagdish_Jain_APqq
    Cupcake Dec 13, 2019
  13. Horsault
    Marshmallow Moderator Dec 13, 2019
    Horsault , Dec 13, 2019 :
    I'm sorry for you, really, but you must know registered patterns DON'T change just by themselves. A human intervention is needed (yours, or someone's who saw your pattern).
    A pattern is easy to spot for someone even a bit far from you. PIN codes are more difficult to spot as long as you don't use a single finger.
    This is why the strongest security is still fingerprint.
    I'm afraid there's no help to expect, unfortunately. You'll only be able to recover data which were previously synced on another support (or in the cloud), unless you can decrypt your storage by yourself using one of the securities you set on your device.
    It's important to set at least 2 ways of unlocking a device, in case you need it. Even fingerprints, set at least 2 of them (imagine your only finger registered is covered by a compress).
    It's also vital to always backup or sync mobile data on a safe place, as any mobile device can be stolen, broken, or failing due to wear.
  14. Swati@Sawale
    Froyo Dec 14, 2019
