forgot the password of secure box
  1. _Piyush_kadam_
    Cupcake Oct 6, 2017
    Ravi BINAVAT likes this.
  2. Diogo Costa10
    Gingerbread Oct 6, 2017
    Diogo Costa10 , Oct 6, 2017 :
    I don't think is possible the only idea I have is to do a factory reset and format the data.
  3. Budruel
    KitKat Oct 6, 2017
    Budruel , Oct 6, 2017 :
    Now you know that the safe box is ... How the hell can you forget the password of your safe box?
  4. Magnetic Nerd
    Jelly Bean Oct 6, 2017
    Magnetic Nerd , Oct 6, 2017 :
    How can you forget your password? Seriously?
    But anyway can't you open it with your fingerprint?
  5. AbandonedTrolley
    AbandonedTrolley , Oct 6, 2017 :
    Try Cupcak3
    G_Piyush_kadam_IUlb and Nezumi_ like this.
  6. SurajLoharia
    KitKat Oct 6, 2017
    G_Piyush_kadam_IUlb likes this.
  7. Yourlocalbartender
    Froyo Oct 6, 2017
    Yourlocalbartender , Oct 6, 2017 :
    You should just be able to access the files with another file manager program without even knowing your password, it's a flawed system. Make sure you turn on hidden files in your file viewer, at the root of your internal storage there should be something that has "securebox" or something similar to click on.
  8. Kamal Hans
    Ice Cream Sandwich Oct 6, 2017
    Kamal Hans , Oct 6, 2017 :
    Tried to Google for a workaround but couldn't find any.
    There doesn't seem to be any option except wiping all your data by going into the recovery mode, and then putting in a password all over again.
    If you just want access to the hidden files, download ES File explorer,go to internal storage, toggle on 'show hidden files', and then go to the dot file manager folder, look for a folder called Safe, tap on it & you'll be able to see your hidden files.
    Cheers.
  9. G_Chaithanya_Chary_yBuB
    Froyo Oct 6, 2017
    G_Chaithanya_Chary_yBuB , Oct 6, 2017 :
    the secure box thing is just crap. data inside it is not at all safe and encrypted. anyone can get the files access from the securebox. just install any other file explorer's like ESExplorer. and toggle show hidden files and search for folder .fileManager... inside that folder u'll find everything that u had in ur securebox. never trust securebox. LOL.
  10. Kamal Hans
  11. SurajLoharia
    KitKat Oct 6, 2017
  12. _Piyush_kadam_
    Cupcake Oct 13, 2017
    SurajLoharia likes this.
  13. SurajLoharia
    KitKat Oct 13, 2017
  14. BeingIncog
    Nougat Oct 13, 2017
    BeingIncog , Oct 13, 2017 :
    You can use your fingerprint to unlock!
  15. jungleboyE
    Honeycomb Oct 13, 2017
    marcusskyfall likes this.
  16. _Piyush_kadam_
    _Piyush_kadam_ , Oct 13, 2017 :
    Yes! but I can't change the old pin.
  17. BobbyV8_
    The Lab² Reviewer - Insta360 GO 2 Writers' Club Oct 13, 2017
    BobbyV8_ , Oct 13, 2017 :
    Backup>Reset device > Restore backup > Move on
    Life is really bigger than your secure box you know
  18. Robertogl2
    Froyo Oct 13, 2017
    Robertogl2 , Oct 13, 2017 :
    Just go into '/storage/emulated/0/.fileManager/safe/files'
    Your files are here, unencrypted, with different names.
  19. Atiqa_Khan
    Cupcake Aug 1, 2019
    Atiqa_Khan , Aug 1, 2019 :
    Helped me :)
