7
Forgot Unlock Pattern ! Help to bypass it
Thread Status:
Not open for further replies.
  1. t-uzun
    Honeycomb Nov 15, 2014
    t-uzun , Nov 15, 2014 :
    hey tonight i change my unlock pattern and when i woke up again i didnt remembered it anymore and now i cant go in to my phone what can i do? there are important things on the phone i know i should have been careful but i am human too!
    PLEAAASE HELP ME
    PS; When it says forgot unlock pattern enter email and password i do it but nothing happens!!
  2. njking25
    Donut Nov 15, 2014
    njking25 , Nov 15, 2014 :
    Hmm...if its anything like cm11 on other devices keep trying. If that doesn't work shut off the phone. You should be able to hold down the power button to turn it off. Then turn it back on and try again. If that still doesn't work you might just have to take the hit and factory reset your phone. Hope I helped.
  3. t-uzun
    UPDATE IAM IN MY PHONE NOW AFTER OVER A HUNDRED TRYS I DID IT BUT I STILL FORGOT IT HAHAHAHAHA
  4. Inzun
    Jelly Bean Nov 15, 2014
    Inzun , Nov 15, 2014 :
    Almost impossible to bypass. Try to go for factory reset. I am not responsible for lost of data or anything wrong with your phone. Resetting your phone will make your data go missing.
    kushal.bhattad and leemartin like this.
  5. kuri7650
    Gingerbread Nov 15, 2014
    kuri7650 , Nov 15, 2014 :
    Usually if you enter the wrong pattern a couole of times it will ask you to put in your numeric pasword
    kushal.bhattad likes this.
  6. addam
    KitKat Nov 15, 2014
    Klue07 and Darko87 like this.
  7. meatandy
    Oreo Nov 15, 2014
    Ceasedd likes this.
  8. DrJMun
    KitKat Nov 15, 2014
    DrJMun , Nov 15, 2014 :
    I'm pretty sure that there's a backup mechanism for getting into the phone besides the pattern. PIN number? Did you set that up?
    kushal.bhattad and stephenlotus like this.
  9. amitranjan
    Froyo Nov 15, 2014
    amitranjan , Nov 15, 2014 :
    One way out. You have to delete all your key files from system folder. Try this.
    Connect you device with usb and run following command. If you are not able to do so, i am afraid. You need a full wipe.
    adb devices
    adb shell
    cd data/system
    su
    rm *.key
    Even if shows lock screen after reboot, try a easy random pattern.
  10. go for.android13
    go for.android13 , Nov 15, 2014 :
    This has helped me once before but you have to be root to work if no root factory reset only way
  11. jkramrsr
    Cupcake Feb 8, 2015
    jkramrsr , Feb 8, 2015 :
    hi friends tried above process still not able to open pattern lock please help.
  12. Skf123
    Marshmallow Feb 8, 2015
    Skf123 , Feb 8, 2015 :
    Is your phone currently connected to the internet?
    Edit: I just noticed this question was asked in November lol
  13. FoleyRose
    Ice Cream Sandwich Feb 8, 2015
  14. afric321
    Eclair Feb 8, 2015
  15. Maximus12
    Honeycomb Feb 8, 2015
  16. AntMunny
    KitKat Feb 8, 2015
    AntMunny , Feb 8, 2015 :
    I'm trying to break into a phone with a pattern...
    how do I do this?
    *kidding*
  17. hadighattas
    hadighattas , Feb 8, 2015 :
    You can bypass it if you enter your google account under forgot my pattern on lockscreen it appears after few failed tries in CM11S.
  18. hadighattas
    Just read what I write in the post right before this one.
  19. leemartin
    Lollipop Feb 8, 2015
    leemartin , Feb 8, 2015 :
    I would not advise you to forget you Password, pincode or unlock pattern....
    Ceasedd likes this.
  20. theshinybeast
    theshinybeast , Feb 8, 2015 :
    That´s exactly what I thought , kidding ? Maybe not o_O
