Forgotten Bluetooth Device Recovery
  1. Suneal Patel
    Cupcake Sep 28, 2020
    Suneal Patel , Sep 28, 2020 :
    Hi, I just brought One Plus Bullet Z Bluetooth ear phones, while connecting it to my one Plus 6 phone I accidentally pressed Forget this Device, Since then I tried to re pair with Bullet Z it's not pairing at all, please help.
  2. Caomhin
    Marshmallow Sep 28, 2020
    Caomhin , via OnePlus 6T , Sep 28, 2020 :
    Reset the Bluetooth adapter on the phone
    Go to Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
    Then restart the phone.
    Also reset the Wireless Z earphones.
    To reset your OnePlus Wireless Z earphones,
    Press the "Volume Up" and "Volume Down" button together for 10-12 seconds. You should hear 2 beeps which means they are reset.
    Then pair them back up, see. If that helps.
    drl431 likes this.
  3. Suneal Patel
    moments after I posted this query, I just tried restarting my phone and it worked.😀
    Thank you though for responding. [e]1f44d[/e]
    Caomhin likes this.
  4. Caomhin
    No problem, you're welcome 😎[e]1f44d[/e]
