Found solution atlast for One Plus 3 T Battery drain
  1. mighty beast
    Froyo Mar 6, 2017
    mighty beast , Mar 6, 2017 :
    Guys,
    In continuation to my earley post, I have found one important root cause for One Plus 3 T battery drain.
    The main culprit app is facebook.
    When you open facebook it internally creates N number of threads to connect to several API services thereby drinking the mobile resources.
    SOLUTION:
    Uninstall the Facebook and browse the Facebook contents from Chrome browser. You can notice 100% percent improvement in battery life.
    Enjoy folks. Please put your comments as well.
  2. Ezito
    Donut Mar 6, 2017
    Ezito , Mar 6, 2017 :
    Mine has been the same with or without the Facebook.
    what has been damning my battery is Android System and Android OS, even with autosync disable and backup disable.
  3. wong36987
    Cupcake Mar 6, 2017
    wong36987 , Mar 6, 2017 :
    Same here
  4. Sumit Punn
    Cupcake Mar 6, 2017
    Sumit Punn , Mar 6, 2017 :
    Some third party apps also drinks battery alot we should check our battery statics
  5. IamNahId
    Froyo Mar 6, 2017
  6. G_Виталий_Ряб
    Donut Mar 6, 2017
    dbau071101 likes this.
  7. Bartnl
    Lollipop Mar 6, 2017
    Bartnl , Mar 6, 2017 :
    Facebook (or any other app) is only a problem when it is at the top of power eating apps in the battery stats. If it isn't listed on top there, it' not the cause.
    And FB solved that problem some time ago.
  8. varunh
    Froyo Mar 6, 2017
    varunh , Mar 6, 2017 :
    after update to 7.1.1 open Beta 3, Bluetooth is killing battery exponentially! whole day phone was hardly used for 30 mins. most of the time on wifi and data was always turned off. still at end of day at 8:00 PM it was 30% from 99% 12 hours ago...
  9. Dunnow
    The Lab - OnePlus 6 Reviewer Mar 6, 2017
