found way to end RCS sucking battery after oreo!
  1. jothivanan
    Froyo Oct 18, 2017
    jothivanan , Oct 18, 2017 :
    Before i complained that rcs ( something poped out after oreo update) sucking battery even than os and other apps. Just found a way. I went to developer options enabled advanced reboot. Then rebooted phone in recovery mode. Then wiped cache. Now i dont see RCS on my phone. And battery its showing more time left after wiping cache
  2. Master_TC
    KitKat Oct 18, 2017
  3. Kiran.a.joseph
    Jelly Bean Oct 18, 2017
    Kiran.a.joseph , Oct 18, 2017 :
    I have done cache wipe in recovery mode, but I still have RCS using battery
    Due to mobile connectivity issues after oreo update, I am not using OP3T much. Hope the connectivity issue will be resolved in future updates.
  4. G_Avee_B_Xaxb
    G_Avee_B_Xaxb , Oct 18, 2017 :
    rcs when gone is replaced by android system,,, when it is present then android system is nowhere. so I'm guessing they are 1 and the same.
    Scorpion_2503 and Arun Sharma like this.
  5. tejakgp
    Honeycomb Oct 18, 2017
    tejakgp , Oct 18, 2017 :
    They are same.
  6. rahuldw181
    Ice Cream Sandwich Oct 18, 2017
  7. G_Zeng_Xing_vCWw
    Cupcake Oct 18, 2017
  8. SatriaPr
    SatriaPr , Oct 18, 2017 :
    I've found a way too that is to disable the Bluetooth scanning for location.
  9. SatriaPr
  10. darius1988
    KitKat Oct 18, 2017
