Fps meter not showing, please help via OnePlus 8
  1. Hassankhanjoiya
    Cupcake Sep 22, 2021
    Hassankhanjoiya , via OnePlus 8 , Sep 22, 2021 :
    i have OnePlus 8
    I have updated my phone
    It's android 11 with Oxygen OS 11.0.8.8.IN21BA
    I have updated game space from store too but i still can't access the fps meter ,hope someone will help me out
  2. Aaron2017
    Lollipop Sep 22, 2021
    Aaron2017 , Sep 22, 2021 :
    The data monitor, and the fps meter, are not available yet in the stable builds for 8 series. It's only available in the beta builds
    Hassankhanjoiya likes this.
  3. Hassankhanjoiya
    How can i download the beta version?
  4. Aaron2017
    That would require you to first downgrade to an older stable version because the version you are on is a newer one than that beta. I would not do that because the beta program has ended so it won't get updates anymore and you would eventually have to switch back to the stable channel anyway. I can get you the link you need to downgrade tho if you still want to install the beta
    Hassankhanjoiya and McJader like this.
  5. Hassankhanjoiya
  6. Aaron2017
    Alright, here they are
    https://forums.oneplus.com/threads/...-11-open-beta-1-for-oneplus-8-series.1296568/
    Select the rollback package you need, you can find them in the first post under "want to go back to MP, download the rollback package below"
    This will wipe all data so don't forget to back up everything first.
    This will take you back to android 10, after that is done, download the full beta 12 zip file from an app called oxygen updater and install that via local upgrade.
  7. SIDD7411
    Honeycomb Sep 22, 2021
