Framerates Drop on Oneplus6t via OnePlus 6T
  1. pdocted
    Cupcake May 12, 2021
    pdocted , via OnePlus 6T , May 12, 2021 :
    After the recent security update, My oneplus 6t phone feels very sluggish and having pretty bad experience overall.
    Having massive frame rates drop even during normal scrolling and gaming. Phone heats up a lot while gaming. jittering screen.
    Anyone getting same experience??
    love1plus1specs likes this.
  2. Tokolozi
    Most Original Avatar May 12, 2021
    Tokolozi , May 12, 2021 :
    did you try anything yourself yet? Like clearing the device cache from recovery?
    Aaron2017 and K1557328612622 like this.
  3. love1plus1specs
    Gingerbread May 12, 2021
    love1plus1specs , May 12, 2021 :
    Mine been sluggish! Ui Non responsive! Freezes for a few.... My 1st OnePlus 6t needed replacement! (Black screen)! This 6t, issues just as bad! 8 gig ram, tmobile bloatware, 128 gigs of flash! My security update, of course after tmobile mods it, takes additional 3 weeks! 10.3.9 is my os version!
  4. sumitMZ007
    Jelly Bean May 13, 2021
    sumitMZ007 , via OnePlus 6 , May 13, 2021 :
    I guess the update are under baked before pushing to masses! We can only hope for better and stable updates for future which can actually resolve the issues!
  5. pdocted
    Cupcake May 14, 2021
    pdocted , via OnePlus 6T , May 14, 2021 :
    Yeah I did try clearing cache and even data from recovery. the frame rates issue is a bit less now that there arent as many apps as before but the heat is as worse as ever.
  6. Raza_Dawar
    Gingerbread May 14, 2021
  7. pdocted
    I havent traced the exact frames Im getting. but the have been facing lots of jitters in UI itself.
  8. sumitMZ007
    Jelly Bean May 14, 2021
  9. pdocted
    Cupcake May 20, 2021
    pdocted , via OnePlus 6T , May 20, 2021 :
    Ram boost is enabled by default.
  10. B1549932219401
    Cupcake May 28, 2021
  11. B1549932219401
  12. Airzone
    Cupcake Aug 24, 2021
    Airzone , Aug 24, 2021 :
    You should try a factory reset for your device. It's pretty normal for things like these to happen, especially if your phone is pretty old. Or, you can try uninstalling and installing the application again, since you've probably encountered a bug. I know that this is a pain in the ***, but there's not much that you can do, unfortunately. After you've done those two steps, you can check out fixubuntu.com in order to see your current frame rate. If it's the same, then it's probably time to speak with the developers, since the issue definitely comes from them
  13. ScotJohns
    Cupcake Aug 27, 2021
