FRANCO KERNEL HELP
  1. DA7801
    Honeycomb May 27, 2018
    DA7801 , May 27, 2018 :
    Hey there
    I just flashed the FRANCO KERNEL on my OnePlus 3T (rooted with FreedomOS and TWRP)
    my question is that what are the settings to improve the battery life? I was getting 4hrs of SOT previously
    Thanks
  2. BeingIncog
    Nougat May 27, 2018
  3. DA7801
  4. Paschfire
    KitKat May 27, 2018
    Paschfire , May 27, 2018 :
    I've found leaving the majority of FK manager settings as stock yields the best results for performance/battery.
    Though to get some standby time, within Battery Life Lab menu enable reduce max brightness by 20%~40% helps alot, also within Kernel settings menu enable lower brightness dimmer.
    Using the performance profiles using Per-App modes you can tailor the Power_saving, Balanced and Performance profiles to your specific app usage. This will also help get the most out your battery reserves.
    DA7801 likes this.
  5. DA7801
    Thanks buddy
  6. Paschfire
    KitKat May 27, 2018
    You can also assign a QS tile in the notification shade for FK performance profiles, so you can change them on the fly anytime.
    DA7801 likes this.
  7. RASTAVIPER
    Jelly Bean May 27, 2018
    RASTAVIPER , May 27, 2018 :
    Don't expect any miracles by just using a custom kernel.
    There are other tweaks that help optimizing the battery life when you have root
