freezing notification drawer via OnePlus 6T Mirror Black
  1. Caomhin
    KitKat Jan 26, 2020
  2. #4
  3. tide1109
    Ice Cream Sandwich Feb 12, 2020
    tide1109 , via OnePlus 6 , Feb 12, 2020 :
    I face this issue often on the Open Beta 4 and earlier beta versions.
    It's only a short time after unlocking. For fixing you have to lock your phone and then unlock it again.
  4. Caomhin
    KitKat Feb 12, 2020
    Caomhin , via OnePlus 6T , Feb 12, 2020 :
    Try updating the OnePlus Launcher, see if this helps
    This one was released Feb 7th 2020
    https://www.apkmirror.com/apk/onepl...-4-200207114119-981a919-android-apk-download/
  5. tide1109
    I use Nova Launcher. My Nova Launcher and the OnePlus Launcher is up to date. I am on the Beta channel of both launchers but that shouldn't be the problem too.
    I think the issue has nothing to do with the launcher. It's a problem with the System-UI.
    lSIMRANl likes this.
  6. Caomhin
    KitKat Feb 12, 2020
    tide1109
    I think the issue has nothing to do with the launcher. It's a problem with the System-UI.​
    There are known issues with Nova Launcher and Android 10, you will have to check with Nova Launcher developers on that. My suggestion was for the OnePlus Launcher only.
  7. lSIMRANl
    Cupcake Feb 23, 2020
    lSIMRANl , Feb 23, 2020 :
    Hey bro i have the same problem and I am also using Nova Launcher. Did you find the solution to this problem?
  8. tide1109
    Ice Cream Sandwich Feb 23, 2020
    tide1109 , Feb 23, 2020 :
    I don't exactly know, when this appears. I know it only happens a short time after unlocking the phone and directly opening the notification panel. But this is not consistent. Sometimes it happens every time and sometimes it doesn't apply.
    Some times I can't open the notification panel. So it's closed an I can't open it. Locking and unlocking fixes it. This is also in other apps.
    The thread creator seems to use the OnePlus Launcher. The probability may be higher with Nova Launcher but it's not limited to it.
