freezing
  1. Napari Diya
    Cupcake May 3, 2018
    Napari Diya , May 3, 2018 :
    it freezes soooooo much that, it takes some days before it works or I restart, flush and soooo on. help me with this
  2. danevans17
    Ice Cream Sandwich May 3, 2018
    danevans17 , May 3, 2018 :
    Have you done the usual clear cache from recovery?
    If so, what about factory reset?
    I would do a factory reset and be careful of what apps you install as apps can cause serious issues depending on what they are used for.
    Napari Diya likes this.
  3. keithnyc
    Lollipop Moderator May 3, 2018
    keithnyc , May 3, 2018 :
    Alttough there are built in tolerances, safety information indicates that you should ideally operate your phone between -10-35°C temperature
    TrippyZ and Napari Diya like this.
  4. Napari Diya
    Cupcake May 3, 2018
    thank you dear
  5. Napari Diya
    Cupcake May 3, 2018
    ok
  6. Nick 59
    Lollipop May 3, 2018
    Nick 59 , May 3, 2018 :
    It would be "soooooo" helpful if you could provide a lot more detail.
    Which version of OOS are you using?
    Exactly when does phone "freeze"?
    Any error messages?
    When did issue start?
    What steps have you tried to resolve it?
    "And soooo on." Help us to help you. [e]1f609[/e]
    RASTAVIPER and lostLambda like this.
  7. Napari Diya
    Cupcake May 3, 2018
    OOS 5.0.1
    phone freezes at anytime and keeps solo long before it starts working
    I only see something like send us feedback etc
    issue started right after screen broke and was changed
    I have flashed it severally but still same
    please help me I really like my phone
  8. Nick 59
    Try and get the error message if you can. Pic from another phone might help.
    If issue started after a screen replacement there is a strong possibility the repair was not performed correctly.
    I would contact support here:
    https://www.oneplus.com/support/
  9. Yogesh Datar
    Honeycomb May 4, 2018
    Yogesh Datar , May 4, 2018 :
    couldnt help asking what exactly are you flushing?[e]1f60a[/e]
    just joking! no offence.
  10. lostLambda
    Lollipop May 4, 2018
  11. PTuT
    Jelly Bean May 4, 2018
    PTuT , May 4, 2018 :
    Is the camera app as good as stock? I used Lineage on my older device and loved it.
    lostLambda likes this.
  12. lostLambda
    Lollipop Jun 1, 2018
    lostLambda , Jun 1, 2018 :
    I use Open Camera
    PTuT likes this.
