frequent Bluetooth connection drops with bluetooth headsets
  1. Nitikhel
    Eclair Jun 15, 2019
    Nitikhel , Jun 15, 2019 :
    I bought a new wireless headset in which connection drops frequently, i tried the headsets with other phone in which no problem while using the same headset. Even the sound quality with other Moto phone is better.
    Can anyone help with regards to this issue.
  2. TheMystic
    Lollipop Jun 15, 2019
    TheMystic , Jun 15, 2019 :
    Mine doesn't even show up on my 3T on Android P OOS.
  3. Nitikhel
    Eclair Jun 15, 2019
    Its not because of update bro...
  4. TheMystic
    Then what? Everything was fine on Oreo as well as Pie custom ROMs.
  5. Nitikhel
    Eclair Jun 15, 2019
    about a year back I bought a wireless headset in which the same problem I faced , at that point of time I chose to return the headsets. Now i think its hardware issue.
  6. TheMystic
    Possible, not sure. Does it happen with other wireless headphones too? Mine was working fine without issues until P. Now the headset doesn't even show up when searching for Bluetooth devices.
  7. Nitikhel
    Eclair Jun 15, 2019
    for your problem, i think you should go to reset then reset Bluetooth and network settings then try.
  8. TheMystic
    Done all that. Didn't help.
  9. funkmeizter
    Cupcake Jul 6, 2019
    funkmeizter , Jul 6, 2019 :
    I have the same issue. The phone is in my pocket, so it is close by.
    Have experienced it on two different headsets, so it is not the headset.
    However, when I have it connected to my car, I experience no dropouts, but it has sometimes difficulty in connecting to the car.
    Generally, I find the bluetooth experience on this phone quite unsatisfactory.
