Frequent wifi connection drops
  1. guptagaurav
    Cupcake Feb 4, 2020
    guptagaurav , Feb 4, 2020 :
    observing frequent drops in wifi connection,
    WiFi connection drops and takes a second or two to get reconnect, happening intermittently
    this causing issue during online payments as well..
    is anyone one else facing same??
    laurenzo87 likes this.
  2. Caomhin
    KitKat Feb 4, 2020
    Caomhin , via OnePlus 6T , Feb 4, 2020 :
    If you haven't already updated to 10.3.1, use 3rd party Oxygen Updater from the Playstore to download and update to 10.3.1
    You can also try resetting the WiFi,
    Settings, System, Reset Options, Reset WiFi
    Kytharsis likes this.
  3. guptagaurav
    Cupcake Feb 18, 2020
    guptagaurav , Feb 18, 2020 :
    thanks
    oxygen os is already on 10.3.1, however issue still persists
    will try network reset
  4. guptagaurav
  5. Caomhin
    KitKat Feb 18, 2020
    Caomhin , via OnePlus 6T , Feb 18, 2020 :
    You could try backing up your phone and do a full factory Delete All Data reset.
    Or contact OnePlus support directly.
    Scroll down the page for contact details.
  6. sawalmeh95
    Cupcake Feb 19, 2020
  7. guptagaurav
  8. Y1549057751236
    Cupcake Feb 20, 2020
  9. yourparthi
    Cupcake Feb 22, 2020
    yourparthi , Feb 22, 2020 :
    During that wifi signal disruption, sim network is also getting disconnected (call also drops) and getting reconnected in 2-3 seconds.
    tried factory reset too. looks like hardware issue
  10. G_Radek_Cebeniak_RshU
    Cupcake Feb 28, 2020
    G_Radek_Cebeniak_RshU , Feb 28, 2020 :
    sorry but have no idea what's going on with loosing WiFi connection all the time. when bought the phone there was no issues, now I wish to give back and forget. model 3T was excellent, but 6T is scrap! anyone help? have newest soft and nothing change .... very disappointed. please note that the issue came up on all WiFi connections - not only one..
  11. Caomhin
    KitKat Feb 28, 2020
    Caomhin , via OnePlus 6T , Feb 28, 2020 :
    Try reset the WiFi adapter. See if it fixes the issue.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
  12. G_Radek_Cebeniak_RshU , via OnePlus 6T , Feb 28, 2020 :
    tried all these... the mobile is rubbish. just wondering if I can make official complain or exchange, I have original packaging but no receipt. got enough don't know why paid so much money...
  13. Caomhin
    KitKat Feb 28, 2020
    You can contact OnePlus support directly for more information on your issue. Scroll down the page for contact details.
  14. et121677
    Froyo Mar 22, 2020
  15. Caomhin
    KitKat Mar 22, 2020
    Caomhin , via OnePlus 6T , Mar 22, 2020 :
    Have you tried the suggestions to fix the issues as stated above and also on the other thread where you posted the same issue.
    https://forums.oneplus.com/threads/new-update-froze-some-app.1199174/
    If you have and its not fixed then try the following.
    Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of Android. So you will need to backup your phone.
    After Backing up the phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
  16. et121677
    Froyo Mar 29, 2020 at 5:58 AM
    et121677 , via OnePlus 6 , Mar 29, 2020 at 5:58 AM :
    well... was hoping to avoid a factory reset but it appears it's all I got left. love the snarky reply though. keep up the good work [e]1f44c[/e]
  17. Caomhin
    KitKat Mar 29, 2020 at 8:53 AM
    Caomhin , via OnePlus 6T , Mar 29, 2020 at 8:53 AM :
    What's snarky, I gave you suggestions that may hopefully fix the issue, there were also suggestions in the other thread you posted in. Less of the attitude dude.
