2
Frequent wifi connection drops
  1. MarkDillon
    Donut May 8, 2020
  2. Artemus.
    Community Hero 2020 May 8, 2020
    Artemus. , May 8, 2020 :
    Read the device subforum name. This is for 6/6T, not 8 Series.
    Caomhin likes this.
  3. MarkDillon
    Donut May 8, 2020
  4. peakcomp206
    Cupcake May 17, 2020
    peakcomp206 , May 17, 2020 :
    But this is tied in directly to his device as well; Seems related. My 7T Pro McLaren is doing the same thing.
    This seems to be 100% neglect on OnePlus' part. Especially given the 8 that just came out is dropping connections too!
    We all just want OnePlus to address the multi-device issue so that we can all have working phones!
  5. peakcomp206
    Clearly all related to the OxygenOS build. Especially since the 8 that just came out is doing it too!
    MarkDillon likes this.
  6. Artemus.
    Community Hero 2020 May 17, 2020
    Artemus. , May 17, 2020 :
    My OP6 has not been dropping ANY connections. Maybe you have MAC filtering on?
    rhyd1am and Caomhin like this.
  7. peakcomp206
    I do not. What about the entire internet? Across multiple OnePlus devices.....do they all have Mac Filtering on too?
  8. Artemus.
    MAC filtering is done on the router and is used to limit devices that can connect to said router. Android 10, by design, defaults to "randomized MAC addresses" and MAC filtering can be the cause of this.
  9. MarkDillon
    Donut May 18, 2020
    MarkDillon , via OnePlus 8 Pro , May 18, 2020 :
    nope didn't fix for me
  10. peakcomp206
    Cupcake May 22, 2020
    peakcomp206 , May 22, 2020 :
    my router does not have Mac Filtering on.
  11. vegasmason
    Cupcake Jun 5, 2020
    vegasmason , Jun 5, 2020 :
    This is also happening on OP7 Pro. Was working perfectly for the first two months I had it. Updated it last week and within minutes it started randomly disconnecting. Note this is the TMobile version with 10.0.4.
    As luck would have it I have a 2nd OP7 Pro arriving in the mail today for my wife. Any bet it will experience the same problem?
  12. pkondekar29
    Cupcake Jun 24, 2020
    pkondekar29 , via OnePlus 7 , Jun 24, 2020 :
    I am also facing the same issue for months now.. even though i am on the latest OS. Not going to use oneplus phones ever again. Cant even fix a simple issue for which mobile phones are built for
  13. tonnic
    Eclair Oct 24, 2020
    tonnic , Oct 24, 2020 :
    What a stupid recommendation to reset your phone. Can you imagine everytime something in your computer didn't work and they said to reinstall windows? Terrible solution to tell people to do full wipes.
    Oh I have the same problem too btw
  14. Caomhin
    Community Hero 2020 Oct 24, 2020
    Caomhin , via OnePlus 6T , Oct 24, 2020 :
    Computer is a different more open system. Whereas android is not as open, impossible to change hardware drivers on older devices. Windows, Linux, OSX are more compartmentalised so cannot be compared.
    Sometimes a reset in Android can rectify the issue, not always, but sometimes when all else fails. Try searching this forum for solutions as there are many threads that discuss the same issue.
    You might get lucky.
  15. K1578856315812
    Cupcake Oct 28, 2020
    K1578856315812 , Oct 28, 2020 :
    If you're experiencing intermittent mobile data loss, meaning the cell bars are gone and you have no texting, calls, or internet ability other then wifi and if you bought the phone directly from Oneplus, you need to make sure that the sim card is 1. a VOLTE and 2. that the CDMA-LESS (assists in network provisioning) is activated by the carrier. Reach out to the carrier and this will fix it. Even if your cellphone started off working and weeks or a month later you begin to experience this issue, call the carrier and make sure the 1. and 2. are both true.
  16. davrog
    Cupcake Feb 12, 2021
    davrog , Feb 12, 2021 :
    Same on OnePlus 6T (I have google wifi mesh routers at home), but I found a solution in one of the Samsung forums.
    Go into Settings -> Location -> Turn off Google Location Accuracy.
    Absurd. It works. (tested on two 6T devices)
