18
Network/Connectivity Frequent WiFi drops
  1. vincentwhalley
    Donut Jan 4, 2017
    #41
  2. rbaria
    Cupcake Jan 5, 2017
    rbaria , Jan 5, 2017 :
    It doesn't seem to be hardware issue. No disconnects in 3.5.4 M. Started with OOS 4 update. Frustrating.
    #42
    fairy_blue and G_T._A._CxNO like this.
  3. chris.walker
    Gingerbread Jan 5, 2017
    chris.walker , Jan 5, 2017 :
    Perhaps the 7.0 update has enabled the Smart Network Switch by default? If it's on, try turning it off so it doesn't keep switching between wi-fi and mobile network connection.
    #43
    fairy_blue likes this.
  4. Solexje
    Froyo Jan 5, 2017
    Solexje , Jan 5, 2017 :
    Same problem here.....On my OPX and OPO stable good wifi at home and on OP3T fluctuating constantly between low and sufficient to good.
    I am on Nougat stable version. Also on version before same problem. So hardware?????
    #44
  5. fairy_blue
    Cupcake Jan 5, 2017
    fairy_blue , Jan 5, 2017 :
    Same. I get this a lot with facebook and YouTube. But less for lighter apps.
    #45
  6. twist_and_shoot
    Donut Jan 5, 2017
    twist_and_shoot , Jan 5, 2017 :
    Same problem here since day 1 one my 3T. Same problem after upgrading to Nougat.
    Tried to reset network parameters, disabled smart switch didn't fixed anything.
    Same issue happen on diffrents AP 2,4/5 Ghz.
    didn't have any trouble with my Moto X Play.
    I guess I'll go for a refund and buy another brand because it is a really big issue for me and I don't wanna get stuck in this situation...
    #46
  7. G_T._A._CxNO
    G_T._A._CxNO , Jan 5, 2017 :
    so sad... i had many phones before. but OP3 is the first one with such big and annoying issues.
    #47
    fairy_blue and twist_and_shoot like this.
  8. Kobo11
    Cupcake Jan 7, 2017
    Kobo11 , Jan 7, 2017 :
    same here and also bluetooth problems ... really oneplus you can do better please don't ignore all of us who trusted you....
    #48
  9. MariusB19
    Donut Jan 8, 2017
    MariusB19 , Jan 8, 2017 :
    Same problem, my wifi keeps toggling on and off, i didnt have the problem on android 6
    #49
  10. andreaserbe
    Cupcake Jan 10, 2017
    andreaserbe , Jan 10, 2017 :
    same here. WiFi sometimes does not connect after upgrading to 4.0.1. WiFi network sometimes being marked as disabled afterwards. With low signal strength connections is not working at all - before the upgrade I had no issue at the exact same position.
    Already tried:
    - switching WiFi off and on again
    - phone reboot
    - deleted WiFi networks and re-configured
    - wiped cache
    #50
  11. Kearneybobs
    Cupcake Jan 11, 2017
    Kearneybobs , Jan 11, 2017 :
    This is pretty much happening to me too. Wifi is staying on and just disconnects from WiFi and then reconnects in a few seconds. No other devices are doing the same.
    Wifi channel changing hasn't resolved it for me and was happening before the nougat update. Router is only 2.4gHz.
    #51
  12. xblubb
    #52
  13. jordan.jones83
    Cupcake Jan 13, 2017
  14. Synaptx
    Cupcake Jan 14, 2017
    Synaptx , Jan 14, 2017 :
    Not sure if I actually experience a "full" disconnect. But we have the upload and download triangles on our notification bar. When connected to WiFi, i would see these triangles disappear beside a the WiFi symbol and appear beside my mobile signal icon. But in a few seconds, they reappear on the WiFi side. When this happens my WiFi symbol remains with full bars.
    Is this just a glitch or indicating some kind of connectivity issue? I did full reset and wiped my cache. I also connected to different routers and still get the same thing once in a while.
    Anyone experience this particularly? Or do you all just actually have a disconnection where the WiFi turns off completely?
    #54
  15. pablonzio
    Cupcake Jan 15, 2017
    #55
  16. Vikas Gore
  17. pakordo
    Froyo Jan 16, 2017
    pakordo , Jan 16, 2017 :
    I have the same issue. I have tried all alternatives and not fix the problem. i'll try install OOS 3.5.4 because I updated my phone when it arrived.
    #57
  18. ghostdragons445
    Eclair Jan 23, 2017
    ghostdragons445 , Jan 23, 2017 :
    I also now seem to get an issue where I am connected to the wifi but the limited connection ! is showing and the phone reverts to mobile data until i reconnect to the wifi and is slightly annoying.
    #58
  19. vliu9
    Eclair Jan 23, 2017
    #59
  20. Jyoti_porriya
    Cupcake Jan 23, 2017
    #60
