front camera blur need improvement
  1. 9006328889 Cupcake Jan 13, 2019
    9006328889, Jan 13, 2019 :
    front camera needs improvement it has to recognise the face to do blur because when we take selfie from front camera the back person face is also get blurred
    W1547349284362 likes this.
  2. Kytharsis Lollipop Jan 13, 2019
    Kytharsis, Jan 13, 2019 :
    Can you post an example?
    stbn84 likes this.
  3. 9006328889 Cupcake Jan 13, 2019
    if we take this type of photo in portrait mode the then the both the back face is also got blurred
    and from Redmi it is not blured
  4. stbn84 Froyo Jan 13, 2019
    stbn84, Jan 13, 2019 :
    That's how a depth sensor works...
    If you don't want them to be blurred out, then they need to be at about the same distance as your face, not behind you and not staggered. And the photo you posted is just a normal photo, with zero blur..? I'm confused as to what you're wanting or having issue with.
    Kytharsis likes this.
  5. 9006328889 Cupcake Jan 13, 2019
    I have already deleted the blurred photo it is for example that this type of photo I have taken in portrait mode
  6. stbn84 Froyo Jan 13, 2019
    Are you saying that the photo that's still posted, that in a photo like that with 3 people, 2 of which are behind you, would be blurred out by the OP device and only your face would be clear? If that's what you're saying, that's kind of how it works.. because they're behind you. These aren't professional DSLR's with multiple lenses...
  7. 9006328889 Cupcake Jan 13, 2019
  8. stbn84 Froyo Jan 13, 2019
    And again, your hand is behind you... that's how depth sensors deal with blur in selfies on mobile devices. The only thing that needs a bit of improving in my opinion, is better edge detection.
  9. 9006328889 Cupcake Jan 13, 2019
    but same photo was taken from Redmi note 5 Pro and face is not blurred I think OnePlus 6 camera needs improvement in focus
  10. 9006328889 Cupcake Jan 13, 2019
    I know the Blur quality of Redmi and image clarity is not good but OnePlus have some issues in front camera Portrait mode getting blurred like my hand
  11. stbn84 Froyo Jan 13, 2019
    9006328889
    I can see what you're talking about from this pic, but since it's from a Redmi (and I don't have a ton of experience with Redmi) it's likely a different sensor(s) in the devices, different processing algorithm, etc.
    Kind of how iPhone and Pixel devices have substantially better depth effect features & edge detection. This is one reason why people download the Gcam port for the OP6 & 6T to use, because the processing is better. Give it a try, it might help using Gcam, but I do see what you're talking about now, however.. different devices and OnePlus isn't known to have the best cameras.
  12. 9006328889 Cupcake Jan 13, 2019
  13. 9006328889 Cupcake Jan 13, 2019
