6
Front camera blurry
Thread Status:
Not open for further replies.
  1. Deactivated User
    Aug 23, 2014
  2. SteveD
    Ice Cream Sandwich Aug 23, 2014
    SteveD , Aug 23, 2014 :
    Have you tried putting a different effect on it? I've been a huge fan of the "clear image" mode.
  3. sleepdragonone
    KitKat Aug 23, 2014
    sleepdragonone , Aug 23, 2014 :
    Sound like Patty likes some selfies, but disappointed.
  4. Deactivated User
    Aug 23, 2014
  5. Deactivated User
    Aug 23, 2014
    aleporta15 likes this.
  6. eyyaz
    Froyo Aug 23, 2014
    eyyaz , Aug 23, 2014 :
    Are you previewing the pictures in quickpic? you need to zoom into the image a little to see the sharpness. You might also be shaking the camera too much.
    Also, are you using the front facing camera/shooting in low light?
  7. matthijscremers
    Honeycomb Aug 23, 2014
  8. Wellhat
    Gingerbread Aug 23, 2014
    Wellhat , Aug 23, 2014 :
    I agree, but how can I change the effect for when I use apps like snapchat?
  9. Deactivated User
    Aug 23, 2014
    Anant_Chhabra likes this.
  10. Deactivated User
    Aug 23, 2014
  11. eckbauer
    KitKat Aug 23, 2014
    Silenced and obiqbal like this.
  12. skavy0120
    Donut Aug 23, 2014
    skavy0120 , Aug 23, 2014 :
    I'm sure that it's software issue, because other thirdparty apps(such as Candy Camera) work quite well.... I think there is a little of delay after taking picture on the stock camera app....
  13. cmartinaa
    J1549086127221 likes this.
  14. mingtrinh
  15. eyyaz
    Froyo Aug 23, 2014
    I think it just comes down to the fact that you're using a front facing camera which is 5mp. That means less light is entering (compared to the front facing), which further results in long exposure times and noise, add in the fact that there is no IS and i think we know why.
  16. sbenson
    sbenson , Aug 23, 2014 :
    Clean your screen.
  17. aleporta15
    aleporta15 , Aug 23, 2014 :
    I agree. Especially because there's no IS. Cyanogen, first thing to fix about the One camera software...even if it's only digital IS.
  18. IWantOneNow
    KitKat Aug 23, 2014
    IWantOneNow , Aug 23, 2014 :
    Have you enabled front facing quality to 100% under the settings menu? Also, try messing with the filters/shooting modes
  19. Wellhat
    Gingerbread Aug 27, 2014
    Wellhat , Aug 27, 2014 :
    Sorry to revive this thread if it's dead but -
    I understand it is a software issue, is there any way to make this problem no longer occur on apps like skype? For me this is only a problem because I can't skype with high quality video that looks good on the front camera
  20. patrickgermany
    Honeycomb Aug 27, 2014
    patrickgermany , Aug 27, 2014 :
    I am also replying to this thread:
    My wife told me about this, didn't notice it at all because I don't use the front cam.
    Inside with lights turned on the front cam in "selfie" mode ALWAYS blurs and overbrightens pictures. No matter if automatic ISO, fixed light settings or changed filters etc.
    I tried to "focus" my forehead and my eyes but no matter how near or far away you move the camera, there seems to be no point where the image is focused right.
    J1549086127221 and obiqbal like this.
