Front camera not working via OnePlus 6T
  1. R.Prashanth_Sharma
    Cupcake Dec 7, 2021
    R.Prashanth_Sharma , via OnePlus 6T , Dec 7, 2021 :
    Camera app is not opening front cam mode. Tried with other apps and same results. Is this some issue with the software?? Or does this something which needs some repair at shop?
  2. Overzee
    Junior Moderator, The Showcase Reviewer Junior Moderator Dec 7, 2021
    Best Answer
    Overzee , Dec 7, 2021 :
    Click and hold on camera app icon, click on 'app-info', click on 'storage' and then select 'clear cache'. Make sure you'll only clear cache, otherwise (with 'clear storage') you'll lose the camera app settings. Check this article for more information and other steps to clear cache.
    Caomhin and R.Prashanth_Sharma like this.
  3. Overzee
    Hi,
    so the back camera works just fine?
    • Did this happen after installing new software or apps?
    • Which OxygenOS version are you currently on?
    • Have you tried to reboot the phone?
    • Have you tried to clear cache of OnePlus camera app?
  4. R.Prashanth_Sharma
    Cupcake Dec 7, 2021
    Yup back cam is just fine. It's the front one. N I can't see it as an available option as well in WhatsApp n few other apps .
    Software not sure when it was but yeah version is 11.1.1.1. reboot yup twice. N cache clear not yet u know the steps?
  5. R.Prashanth_Sharma
    Cupcake Dec 7, 2021
    it worked mate!! Thanks for sharing. Cheers ..
    Overzee likes this.
  6. Overzee
    Awesome, cheers!
    Caomhin likes this.
