Front Camera Overexposure when detecting face
  1. pokarisquad
    Donut Mar 28, 2020
    pokarisquad , Mar 28, 2020 :
    Everytime camera detecting face, camera will increase exposure to max. even my background is wall. always happen when indoor's selfie. ive tried this many times.
    compared to gcam, it can handle the exposure.
    Oneplus camera
    Gcam
    all auto without editing
    i hope oneplus will get an updates for this front camera. especially for detecting face
  2. Kytharsis
    Nougat Mar 28, 2020
    Kytharsis , Mar 28, 2020 :
    Pro-tip: tap the brightest spot in the room so it can adjust the lighting to the proper light.
    Caomhin, Bouncer71 and Naveen Rayala like this.
  3. Priyanshu Sharma
    Jelly Bean Mar 29, 2020
    Priyanshu Sharma , via OnePlus 6 , Mar 29, 2020 :
    Just tap on your face and lower the exposure slider and use HDR for these type of scenarios although it should automatically activate if set to Auto but if not then manually turn on the HDR.
    Caomhin likes this.
  4. pokarisquad
    Donut Mar 29, 2020
    pokarisquad , Mar 29, 2020 :
    i know, tap and lock exposure. but i used for grup selfie only. i just want quick capture. hdr makes my face blur and overwhite. idk.
    just hope oneplus fix this things.
    Caomhin likes this.
  5. Kytharsis
    Nougat Mar 29, 2020
    Kytharsis , Mar 29, 2020 :
    Front camera isn't meant for "group selfies", it's only meant for one person.
    Caomhin likes this.
  6. pokarisquad
    Donut Mar 29, 2020
    what about pixel 3 and any other smartphone which have a wide angle selfie camera. their ads tell us its for group selfies. :)
  7. Kytharsis
    Nougat Mar 30, 2020
    Kytharsis , Mar 30, 2020 :
    Are you serious right now? Like, seriously?
    Caomhin likes this.
  8. pokarisquad
    Donut Mar 30, 2020
    pokarisquad , Mar 30, 2020 :
    selfie or wefie is not the point. i just asking for a overexposure front cam. if this happen in all op6t, its okay. but if only happend to me. there's something wrong with my front cam
  9. Caomhin
    Lollipop Mar 30, 2020
    Caomhin , via OnePlus 6T , Mar 30, 2020 :
    update your camera to the latest version. See if fixes the issues you experience.
    https://www.apkmirror.com/apk/onepl.../oneplus-camera-3-8-113-android-apk-download/
    And Download and install latest version OnePlus Camera Service
    https://www.apkmirror.com/apk/onepl...s-camera-service-2-2-12-android-apk-download/
  10. Kytharsis
    Nougat Mar 30, 2020
    It's the fact you're trying to say "Pixel can do this but OP can't so it's not the same". That's what shocked me.
    Caomhin likes this.
  11. Priyanshu Sharma
    Jelly Bean Mar 30, 2020
    Priyanshu Sharma , via OnePlus 6 , Mar 30, 2020 :
    These apks are from newer op devices and sometimes they don't work well with older devices.
    Sorry for going off topic but what's the breed of the dog in your dp? Is it Beagle? He looks really cute!!😅
    Caomhin and Kytharsis like this.
  12. Caomhin
    Priyanshu Sharma
    I have them installed on my OP6T working fine, also a poster tried it on older OP6, works fine on that too. Wouldn't suggest it unless it worked on both phones.
    It's a Jack Russell, when she was 3 months old, she is now 2 and half years old. Lovely dog, she would nearly talk to you. [e]1f44d[/e]
    Kytharsis and Priyanshu Sharma like this.
  13. Priyanshu Sharma
    I just told because sometimes they create issues anyways no problem.
    Kytharsis and Caomhin like this.
  14. Caomhin
    No worries, I understood where you were coming from. But I will always check by installing on my own phone first. Anyway updated details of the dog in the post above.
  15. Priyanshu Sharma
    That's nice to know! She is really adorable!! I'll also get a dog someday.
    Kytharsis likes this.
  16. Caomhin
    Jack Russell's are quick to learn, from a pup, easy to feed, and small and tidy. But compete nutcases at times. They have an independent streak. But very loyal.
  17. Priyanshu Sharma
    We should continue up in DM.
  18. Priyanshu Sharma
    Front camera has a fixed focus of around 1 metres and if you go beyond that then it'll not be that sharp obviously.
    I don't think HDR makes image blurry instead it increases the dynamic range but i know it's not that good. But don't compare it to Pixels and Gcam they've one of the best HDR processing and they're far superior than OnePlus HDR!
    Anyways you can submit your feedback using this link-
  19. pokarisquad
    Donut Mar 30, 2020
    cz you mentioned it first. so i just want to explained that front cam also for group selfie with wide angle cam.
    thats okay. thanks for ur attention)
  20. pokarisquad
    Donut Mar 30, 2020
