2
Front Camera Too much ZOOMED IN ON SNAPCHAT , INSTAGRAM and WhatsApp
  1. mansih2143
    Eclair May 31, 2018
    mansih2143 , May 31, 2018 :
    sorry for previous thread, I forgot to mention this issue is On snapchat and Instagram..the front camera is too zoomed in these applications (snapchat WhatsApp and Instagram).
  2. mansih2143
    Eclair May 31, 2018
    example.top- from front camera
    bottom - from snapchat's camera!
    same angle and distance
  3. dec1153
    Honeycomb May 31, 2018
    dec1153 , May 31, 2018 :
    Same issue with the 5T. Was never fixed so guessing this won't be fixed here either
  4. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer May 31, 2018
    KeepTransisting , May 31, 2018 :
    It looks like it's the app's fault, not the camera. If you notice, the app fills the screen, so it zooms in the camera and crops off the sides. Whereas in the camera app, it shows the proper 4:3 aspect ratio.
    Nothing OnePlus can do about this, unfortunately. It's up to SnapChat and Instagram to use the proper aspect ratio and not fill the screen.
    You'll notice the same thing if you go into the camera app and change the 4:3 at the top to 19:9
    mansih2143 likes this.
