2
Front camera
  1. D1541428323196
    Eclair Feb 13, 2019
    V1560353908196 and Osmanboi like this.
  2. B_Wrath
    Marshmallow Feb 13, 2019
    B_Wrath , Feb 13, 2019 :
    Okay
  3. stbn84
    Gingerbread Feb 13, 2019
    stbn84 , Feb 13, 2019 :
    It's not THAT bad, but I hope you didn't purchase a OnePlus device based on camera expectations. OP has never been known to be top-tier when it comes to their cams. And usually front cams are the least of importance in comparison to rear shooters.
  4. D1541428323196
    Eclair Feb 13, 2019
    D1541428323196 , Feb 13, 2019 :
    The back camera is pretty decent but the front one is actually that bad. even in good light, the picture turns out to be washed out.
    V1560353908196 likes this.
  5. stbn84
    Regardless, what "mid-range" devices exactly are better than the OP6T, since that's your claim? Just curious.
    Not necessarily saying in your situation, but a lot of "bad quality camera" complaints are due to users not knowing how to take proper photos with the correct lighting, framing, etc.
    Possibility you may have a defective front cam, if your photos are in fact that bad? Post some examples of your shots.
  6. xnutzii
    Lollipop Feb 13, 2019
    xnutzii , Feb 13, 2019 :
    It's the software of the phone which sucks.
    Don't use the OnePlus Camera app, it truly sucks. Even with rear camera pictures.
    D1541428323196 likes this.
  7. Discostu
    Jelly Bean Feb 13, 2019
    Discostu , Feb 13, 2019 :
    Front cameras are rarely amazing. If you want good photos you'll need to make sure you're in well lit stations otherwise it'll probably be poor.
    If it's not good enough then do some research and buy a phone that has a well regarded front facing camera
  8. D1541428323196
    Eclair Feb 13, 2019
  9. stbn84
    Then try the Gcam port. Or buy one of the multiple mid-range devices that you say are better. You have options, nobody is forcing you to use OP.
  10. D1541428323196
    Eclair Feb 13, 2019
    I always use gcam bro its wayyyyyy better, however it crashes more frequently.
  11. stbn84
    Then what was the point of this entire thread you created? Seriously. You don't like the stock cam, you say Gcam crashes, you say mid-range devices are better... what do you want US to do to help you, just being users like yourself? Now it's very apparent you created this thread to just complain, and that's all. You're not looking for help or anything of the sort. Either deal with what you have or sell the OP and buy another device.
    Someone close this thread already.
    Discostu likes this.
  12. v0 HaVoK 0v
    Ice Cream Sandwich Feb 14, 2019
    v0 HaVoK 0v , Feb 14, 2019 :
    Yeah I don't like the stock camera app for front cam, it's blurry and washed out because it seems to prioritize seeing your face too much, it over exposes so that your face is perfectly visible, but its too aggressive in doing this, where Google cam it's more natural light, your face is still visible too but just not as bright
  13. D1541428323196
    Eclair Feb 14, 2019
    D1541428323196 , Feb 14, 2019 :
    Are you stressed with your life or what??, I was just saying, how about if the stock camera is good enough so we can take some good pictures without having any third party camera app which doesnt crash.
  14. Discostu
    Jelly Bean Feb 14, 2019
    Discostu , Feb 14, 2019 :
    To be fair you didn't actually say that.
    You said this: "Front camera quality is so bad, it doest even compare to mid range phones nowadays."
    You also posted it in the support section where people post about issues they need resolved and not nebulous comments about how the front phone quality is bad and doesn't compare to mid range phones.
    OnePlus has a feedback section on their website you can use. I agree, this thread is utterly pointless.
    stbn84 likes this.
  15. F_Mohammed_Salman_NIND
    Gingerbread Feb 14, 2019
    F_Mohammed_Salman_NIND , Feb 14, 2019 :
    The best stable video can be only recorded with oneplus devices. In terms of quality it rivals the big flagships. In terms of video stability its the best in the smartphone market. The only drawbacks are highlights are over exposed and cropping result. Try change your scenario or adjust the frame you will get better results
  16. U1561979252188
    Cupcake Jul 1, 2019
  17. U1561979252188
    Cupcake Jul 1, 2019
  18. JP Llaga
    Froyo Jul 2, 2019
    JP Llaga , Jul 2, 2019 :
    Here's some sample shots:
    Look at that picture... Its a pic when the Build 9.0.4 (i guess )
  19. G1562349695053
    Cupcake Jul 5, 2019
  20. G_Aaro_Hormalainen_Djbc
    Cupcake Jul 19, 2019
    G_Aaro_Hormalainen_Djbc , Jul 19, 2019 :
    Hey, i have the same problem on my brand nee OnePlus 7. My images keep going blurry and it looks like theres some kind of beauty or skin softener on, even though there are not. This is really annoying, i hope that future updates will fix this...
