Frozen OPO - Help pls
  1. Xv1nX
    Donut Dec 27, 2014
    Xv1nX , Dec 27, 2014 :
    Hi guys,
    i tried to make an backup with twrp but now the phone froze. i can´t reboot the phone. It doesn´t recognize the power and +/- buttons. Only the menu bar vibrates on touch.
    How can i reboot the phone? pls help.
    ronoldo likes this.
  2. pipecpa
    Lollipop Dec 27, 2014
  3. Birdchop
    Gingerbread Dec 27, 2014
    Birdchop , Dec 27, 2014 :
    If you can't hold it back anymore, just let it go. Turn away, and slam the door, and cry in a dark corner.
    No pun intended :rolleyes:
    Is this problem similar to the Sleep of Death issue?
    ronoldo likes this.
  4. javedmasi
    Cupcake Dec 27, 2014
    javedmasi , Dec 27, 2014 :
    Reboot is the only solution for opo prbs,, if u cant reboot...hold for while then try
    ronoldo likes this.
  5. ronoldo
    KitKat Dec 27, 2014
  6. jeffreythomas007
    Eclair Dec 27, 2014
  7. leemartin
    TJ COMBO likes this.
  8. Xv1nX
    Donut Dec 27, 2014
    is there a way to reboot the phone? normally i would take the battery off, but it isn´t possible on this phone
  9. TJ COMBO
    Jelly Bean Dec 27, 2014
    TJ COMBO , Dec 27, 2014 :
    I'm never gonna backup with twrp, how can that make your OPO freeze? Amazing!
  10. Xv1nX
    Donut Dec 27, 2014
    thanks, but it doesn`t work. ADB does not recognize the phone
  11. Birdchop
    If you're not satisfied with your item, return it back to Walmart money back guaranteed.
  12. hazzavg
    KitKat Dec 27, 2014
    hazzavg , Dec 27, 2014 :
    I did once
    Use the search function to find my post
    You will find I recommend it as it helps charge the phone and actually increases the battery life as it will hold the charge longer
  13. alchang
    Ice Cream Sandwich Dec 27, 2014
  14. Ycantibeu21
