Gadgetshieldz Skinnova application. Help required..
  1. rajasekaran2050
    Gingerbread Jan 28, 2015
    rajasekaran2050 , Jan 28, 2015 :
    Guys,
    I have received my teak wood skinnova skin. They sent me 1 skin pack and something similar to screen protector with some spray. I am not sure what is it and it is very much confusing on how to apply it.
    Please help..
  2. Vinuraj
    Ice Cream Sandwich Jan 28, 2015
    Vinuraj , Jan 28, 2015 :
    I think this video full explains how to do it :)
  3. rajasekaran2050
    Vinuraj likes this.
  4. Vinuraj
    Sure no problem bro...
  5. Grvnvt
    Grvnvt , Jan 28, 2015 :
    The skin and screen-guard are two separate components.
    You do not require the spray for application of the skin.
    For the skin, you just need to peel it off the 3m adhesive tape and apply it directly after aligning. Preferably use a hair dryer for accurate drying.
    For the screen guard and spray usage the video given earlier should suffice.
  6. sandeeppathak007
  7. navneeta
    navneeta , Jan 28, 2015 :
    I
    Is it worth the effort? In my opinion, apply the skin and on top, use a tempered glass . Forget the bundled screen protector.
    I am thinking to do the same... not bought the Skin as yet
  8. Armsheezy
    Jelly Bean Jan 28, 2015
    Armsheezy , Jan 28, 2015 :
    Don't even think if applying screen guard. Its not worth. Waste of time.
  9. Grvnvt
    Exactly my thoughts..Better opt for tempered glass for screen protection
  10. jain1980
    Gingerbread Jan 29, 2015
    jain1980 , Jan 29, 2015 :
    Using a hair dryer to apply the skins is a must or it won't stick on the corners. The procedure is mentioned on their website too and even in the packaging.
  11. Vinuraj
    Ice Cream Sandwich Jan 29, 2015
    Vinuraj , Jan 29, 2015 :
    Ha that's a hell of a applying skins... better to keep the original ;)
  12. rajasekaran2050
    rajasekaran2050 , Jan 29, 2015 :
    Applied and it is fine. But phone become slippery after applying this skin. Almost dropped phone twice today...
  13. abhibhan89
    KitKat Jan 29, 2015
    abhibhan89 , Jan 29, 2015 :
    Kindly share pics of the phone..
    Also elaborate on the feel of the skin..
  14. navneeta
    navneeta , Jan 29, 2015 :
    Slippery ?.. the wood finish may give a different feel but it is certainly not slippery like the glossy plastic builds of other phones.
    For drop protection use a bumper or clear case.
