bryangmr , via OnePlus 7 Pro , Jan 20, 2020 : Hello, Ik am having troubles with the connection of my Garmin connect app, my phone and my Garmin Forerunner 45. After one day I always lose the connection between my phone and my watch. After the loss, I get the notification that my pop up notifications on my phone are stopped and that I need to restart my phone. After trying this, the problem stats. Anyone with the same problem or with a solution? Kind regards
oOo.Manu.oOo , via OnePlus 6 , Feb 17, 2020 : Have a look on battery optimisation parameter for Garmin connect: You can find it here: Applications and notifications > Application specific access > Battery optimisation I have translated menu so the text may differ a bit.
wejansen , Mar 11, 2020 : I also have this problem. Called Garmin and they don't know what's causing it. I tried to find the battery optimization as recommended above but can't seem to find it in settings??
pgrey , Mar 12, 2020 : The battery optimization settings are under Settings->Battery-Battery-Optimization. I use mine with a 945 all the time (VA 3 before that), have never had to reboot to sync, at least not that I can recall. If you're trying to get it to sync continuously (tough on the battery on both devices, but live-update is a nifty feature, for some), you need to chose the Intelligent or possibly the not-optimized setting, so that the sync can happen in the background, otherwise Android is likely to suspend the app.
C1597700764869 , via OnePlus 7T , Aug 30, 2020 : I have the same problem with my op7t and my fenix 5... I have tried everything but after the first sync my watch cannot sync any more.... I have to uninstall and install the app again and again. From garmin Greece the told me that maybe is my phone's fault. My wife has an iphone 8 with a forerunner 45 and works fine. A friend has a galaxy 10 with a fenix 5 and also works fine. The only thing that i have not done yet is rebooting my phone... Can someone suggest anything else?
JRibeiro_ , Nov 24, 2020 : Hello, I recently bought OnePlus 7 Pro. I'm very happy with the phone, but I can't seem to get incoming calls notifications sent to my Garmin Forerunner 245. I get all other notifications: SMS, Whatsapp messages, emails, etc. But no phone calls or whatsapp calls. I did a lot of research but couldn't find any reason why this is happening. any suggestions?
R.Peter , Nov 25, 2020 : Connect app - hamburger menu in the top left corner - Settings - Notifications - Application notifications. Check what you need and what you want, enable or disable them.
SDesaer , Feb 8, 2021 : Hello I have the exact same problem. And Garmin Belgium told me the exact same thing: "it's a OnePlus-problem". In fact, the Garmin employee even sent me the link to this thread. May I ask if you have found a fix to the problem already? Cheers.
