2
Third Party Software Gboard popup lagging 2-3 seconds
  1. sachin1058
    Donut Apr 8, 2021
    sachin1058 , Apr 8, 2021 :
    I m experiencing a lag of 2-3 seconds in Google keyboard popping up before typing at times. Which is sometimes frustrating . I don't think it should happen on a device like OnePlus 9 pro 12gb 256 . Please help.
    Walhalla and RonNew like this.
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Apr 8, 2021
    sachin1058 likes this.
  3. crazingineer
    Gingerbread Apr 8, 2021
  4. sachin1058
    Donut Apr 8, 2021
    sachin1058 , via OnePlus 9 Pro , Apr 8, 2021 :
    Yes I have updated on the very first day...
    Secondly... It's only happening in few apps.. I have tried uninstalling and installing the same. Again. But the issue won't go. For instance kite by zerodha is really important for me during trading where a single second is also important . But gboard is always taking 2-3 seconds to pop up.
    Can u tell what should I do
  5. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 8, 2021 :
    Since it is limited to certain apps you may want to report it as described. Have you tried the apps on a phone with an Android 11 based OS before? Might be good to also ask the app dev about this behaviour.
    There was no delays on the same apps on the older phone?
    Caoimhín likes this.
  6. sachin1058
    Donut Apr 8, 2021
  7. RonNew
    Eclair Apr 8, 2021
  8. Ossy81
    Donut Apr 8, 2021
  9. Conor97
    Cupcake Apr 8, 2021
  10. G_Nishaant_Sharma_Ywzz
    Eclair Apr 9, 2021
    G_Nishaant_Sharma_Ywzz , Apr 9, 2021 :
    I second that, I also use Kite by zerodha and coin app by zerodha, they have laggy behavior with keyboard(opens after 2-3 sec). Not sure if it is app problem or phone problem because it works fine in other phones.
    Also another annoying problem specific to kite app is when you open it successive times from the opened app drawer, it shows blank screen and you have to click home and open it again then it shows the app. It is really annoying because i open app 20 times a day.
    Thariq.mcknight and sachin1058 like this.
  11. RonNew
    Eclair Apr 9, 2021
  12. sachin1058
    Donut Apr 9, 2021
    sachin1058 , via OnePlus 9 Pro , Apr 9, 2021 :
    I m experiencing the same with kite. Blank screen again and again. Now have to use my OnePlus 6 specifically for kite.
  13. Ruqhaiya Taskeen
    Ice Cream Sandwich Staff Member Apr 10, 2021
    Ruqhaiya Taskeen , Apr 10, 2021 :
    We may have to check this further. Kindly check you're inbox we've dropped you a direct message. It'll be of great help if you could share the required information. 
    Regards,
    Ruqhaiya Taskeen
  14. Walhalla
    Gingerbread Apr 11, 2021
    Walhalla , Apr 11, 2021 :
    I have the same problem on a nearly empty OnePlus 9 Pro with the Microsoft Edge browser. Works like a charm on my OnePlus 8 Pro.
  15. Johan_Dijkstra
    Cupcake Apr 13, 2021
    Thariq.mcknight likes this.
  16. RonNew
    Eclair Apr 14, 2021
    RonNew , via OnePlus 9 Pro , Apr 14, 2021 :
    In my case the issue came back.
    It happens only when I use MS Edge.
    After switching nearly every setting I think I figured it out.
    When I switched from 120Hz to 60Hz refresh rate the issue disappeared.
    I played for several times with the refresh rate switching from 60 to 120 and back.
    Every time with the rate at 120Hz it gave a few seconds leg in popping up the keyboard.
    In 60Hz mode all is normal.
    I hope OP can fix it now.
  17. Thariq.mcknight , via OnePlus 9 Pro Stellar Black , Apr 15, 2021 :
    Same issue I am also facing , at time when I want to enter immediately , the lag causes problem
  18. Thariq.mcknight , via OnePlus 9 Pro Stellar Black , Apr 15, 2021 :
    Tested it , no lag in 60 hz .
    Once I put back at 120 hz then there is lag , oneplus kindly fix the bug
    RonNew likes this.
  19. p373r66
    Froyo Apr 15, 2021
    p373r66 , via OnePlus 9 Pro , Apr 15, 2021 :
    I have a similar problem but not with the keyboard, deleting files from power amp there is a 2-3 second delay before the confirmation dialog appears. Lowered refresh rate to 60, all works ok, going back to 120 the delay is back.
    RonNew likes this.
  20. bdaviesweb , via OnePlus Community App , Apr 15, 2021 :
    I actually just submitted a bug specific to edge browser. Seems to work everywhere else. I also tested with various refresh rates and have seen the same. 60hz it works just fine, 120hz adds the keyboard lag.
