7
Gcam for Android 10
  1. HJ De Vries
    Cupcake Dec 24, 2019
    HJ De Vries , Dec 24, 2019 :
    View attachment 1208588 ]
    Indeed working but still the problem of the front camera only capturing at a max of 4 mp...
    #61
  2. reath123
    Gingerbread Dec 25, 2019
    #62
  3. reath123
    reath123 , via OnePlus 6 , Dec 25, 2019 :
    Fixed issue of front hdr+ and hdr+E mode. Stable mode
    https://drive.google.com/file/d/1m5Uf3QV_Q5THYCNyRBjclt1_ia5KCdml/view?usp=drivesdk
    #63
  4. HJ De Vries
    Cupcake Dec 27, 2019
    #64
  5. reath123
    Gingerbread Dec 27, 2019
    reath123 , via OnePlus 6 , Dec 27, 2019 :
    Yes the front camera max resolution is 4 MP in all GCam7.0 and 7.2. As the max resolution of front camera in pixel 4 series 8MP.
    #65
  6. HJ De Vries
    #66
  7. reath123
    But the quality of the front camera is good.
    #67
  8. HJ De Vries
    Cupcake Dec 28, 2019
    #68
  9. HJ De Vries
    HJ De Vries , Dec 28, 2019 :
    Oh btw, with the last version you posted the astrophotography function is not working... The one before is not available anymore? Tried to download it but won't do. 😢
    #69
  10. reath123
    Gingerbread Dec 29, 2019
    reath123 , via OnePlus 6 , Dec 29, 2019 :
    In the last version you need a tripod to take astrophotography....it will take some time for astrophotography like pixel 4.
    #70
  11. thecipher
    Eclair Dec 29, 2019
    thecipher , Dec 29, 2019 :
    when to use the respective config files????
    I mean which config file is best suited for what kind of photography???
    #71
  12. reath123
    No xml needed
    #72
  13. thecipher
    Eclair Dec 29, 2019
    Then what is the use of those 4 XML files that you made us download?
    #73
  14. reath123
    #74
  15. reath123
    #75
  16. thecipher
    Eclair Dec 29, 2019
    okay....thanks for the information
    #76
  17. HJ De Vries
    Cupcake Dec 29, 2019
    HJ De Vries , Dec 29, 2019 :
    Yep I see a timer that counts from 20 minutes is that normal??
    #77
  18. reath123
    #78
  19. HJ De Vries
    Okay but with the version before the last one it worked very fast. Maybe you can make that one available again?
    #79
  20. reath123
    Gingerbread Dec 30, 2019
    reath123 , via OnePlus 6 , Dec 30, 2019 :
    Actual astrophotography in pixel series take aprox 20 mints. Use a tripod to take astrophotography. Then see the quality of photos.
    #80
