atmilushev , via OnePlus Community App , May 28, 2022 : Hello, Can anyone recommend a working GCAM for OnePlus 10 pro? Thanks in advance!
Swejuggalo , May 29, 2022 : There can be many and doesn't need to be specific for 10 Pro. Unless you also want a XML specific for 10 Pro. A quick googling. https://www.celsoazevedo.com/files/android/google-camera/ https://www.xda-developers.com/google-camera-port-hub/ Also there is no "best" version since that is often a personal preference. I also recommend comparing and reporting situations where you feel the stock camera fails. View attachment 1791208
atmilushev , May 30, 2022 : Thank you! By saying "best" I mean a stable version working well, without functional limitations. I will try a version for Oneplus 9 Pro
Swejuggalo , May 30, 2022 : I'm afraid all lenses are not supported at the moment. On any 3rd party camera. Other than that there should be several that work. Barely made any GCam Vs Stock tests on 10 Pro yet. But based on previous phones it usually ends up with mixed results. The way I see it nice working GCams is the users chance to fully customize the camera experience. While the stock is the universal solution that tries to fit the larger crowd.
