8
GCam Mod apk for OP3 (no root)
  1. swathikrishnavemula Froyo Feb 8, 2019
    swathikrishnavemula, Feb 8, 2019 :
    OnePlus 3T
  2. mohd_areeb Froyo Feb 8, 2019
    mohd_areeb, Feb 8, 2019 :
    it's working in op3! wait for few hours i will upload a new mod for OP3T!
  3. swathikrishnavemula Froyo Feb 8, 2019
    ok sure [e]1f44d[/e]. thanks [e]1f60a[/e]
  4. mohd_areeb Froyo Feb 8, 2019
    Hey! For now slow motion is not supported in Android Oreo! it's supported in Pie or if you want to use slow motion you must have your phone rooted,magisk module flashed, twrp recovery & a patch to flash to use slow motion which i didn't consider to do so! Wait for the pie! Problem will be solved! Will be uploading new Version of this Gcam Modd soon after some testings & getting hands on various settings of the new Mod. Stay tuned![e]1f60a[/e][e]1f609[/e]
  5. S1518053376107 Cupcake Feb 9, 2019
    S1518053376107, Feb 9, 2019 :
    Buenas todos estoy buscando ayuda para poder descargar la aplicación Gcam para mí op3...gracia
  6. mohd_areeb Froyo Feb 9, 2019
    mohd_areeb, Feb 9, 2019 :
    Please describe your query in English Language!
  7. mohd_areeb Froyo Feb 9, 2019
    CAN'T UNDERSTAND "ENGLISH PLEASE"
  8. mohd_areeb Froyo Feb 9, 2019
    Hola, puedes descargar el mod de GCam desde aquí! El enlace se da arriba! Si tienes algún problema, contacta conmigo.
  9. mohd_areeb Froyo Feb 9, 2019
  10. elanglois Lollipop Feb 9, 2019
    elanglois, Feb 9, 2019 :
    I've not had any problems myself
  11. mohd_areeb Froyo Feb 9, 2019
    Capturing, in low lights automatically makes the photo Look alike Thermal image!
  12. elanglois Lollipop Feb 9, 2019
    Not mine. Mine works great. Even very low light looks surprisingly good.
  13. mohd_areeb Froyo Feb 9, 2019
    elanglois
    Not mine. Mine works great. Even very low light looks surprisingly good.​
    don't know but i found many bugs & the selfie camera picture quality is worse! The default camera app has better than it. LOL
  14. elanglois Lollipop Feb 9, 2019
    You must be using a different port or weird settings
  15. mohd_areeb Froyo Feb 9, 2019
    I'm testing every corner of the new mod! So, can't decide which version is better,stable & has high quality image output![e]1f60a[/e]
