Discussion General questions
  1. O1529070652474
    Cupcake Jul 6, 2018
  2. I1534524752515
    Cupcake Aug 18, 2018
  3. script
    Nougat Moderator Aug 18, 2018
    TibiTibi likes this.
  4. yuvaraj_r
    Cupcake Sep 4, 2018
    yuvaraj_r , Sep 4, 2018 :
    Not finding the double press power button for quick capture in the recent update!..
  5. I1534524752515
    Cupcake Sep 9, 2018
  6. TibiTibi
    Photography Expert Sep 9, 2018
    script likes this.
  7. Jakub Rudiš
    Cupcake Sep 19, 2018
    Jakub Rudiš , Sep 19, 2018 :
    I'm using camera a lot, specialy at pro mode, but i want to use whole potencial of the camera, like ISO up to 6400 that Is available in automatic setings, but not in manual setings. And i would appreciate longer shutter speed for example up to 60 seconds.
  8. Horsault
    Marshmallow Moderator Sep 19, 2018
    theshinybeast and Bouncer71 like this.
  9. theshinybeast
    Marshmallow Sep 19, 2018
    Bouncer71 likes this.
  10. Jakub Rudiš
  11. C1538074585472
    Cupcake Sep 27, 2018
  12. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Sep 27, 2018
  13. vrprad
    Cupcake Sep 30, 2018
    vrprad , Sep 30, 2018 :
    anybody have stable google cam apk for oneplus6...after updating to android pie image processing in op6 have some issues..so I decided to try google cam...
  14. script
    Nougat Moderator Oct 1, 2018
  15. av_hash
    Froyo Dec 10, 2018
  16. keybladehero
    Froyo Jan 1, 2019
    keybladehero , Jan 1, 2019 :
    Is the srgb display better for taking photographs and then use it for editing later? I like my photos to be saturated
  17. script
    Nougat Moderator Jan 2, 2019
    script , Jan 2, 2019 :
    I think you should decide this for yourself. Most important is, that you use the brightness at maximum. And then test what display settings you like the most.
    You also could check the same pic on your phone and on a good pc monitor, and then choose the settings on your phone that you like the most.
    I would say, it's a personal setting, so you should just try out what you like.
    I use SRGB.
  18. Mantaii
    Donut Feb 19, 2019
    Mantaii , Feb 19, 2019 :
    Hi everyone,
    Took my OP6t out tonight when I went running and I used to set the timer and take 3 photos one after the other automatically. This was handy for getting action shots and I didn't need to time things perfectly. I had a 1 in 3 chance of getting a good photo.
    That was on my old Samsung S7 so presumed I'd be able to do it on my 6T but I couldn't see the settings.
    Am I missing something or is it not possible?
    Thanks
    #38
