Gestures bar via OnePlus 7T Pro
  1. tugadude4
    Cupcake Nov 26, 2019
  2. barqawi.alaa
    Donut Nov 26, 2019
    barqawi.alaa , Nov 26, 2019 :
    what are you talking about, can't get what you are trying to request. could you elaborate more on that
  3. tugadude4
    Cupcake Nov 28, 2019
    tugadude4 , via OnePlus 7T Pro , Nov 28, 2019 :
    do you know the gestures bar? if so when you have the auto rotate deactivated and if then you rotate your phone you get a prompt on the bottom left corner that you can click and it will rotate, but if you use the option to hide the gestures bar in the options then when you rotate you wont have the prompt for that
  4. TypewriterChaos
    Eclair Dec 22, 2019
