Glass crack from a 50 cm hight fall ! ( One plus 3 )
  1. Sud_oneplus
    Cupcake May 20, 2018
    Sud_oneplus , May 20, 2018 :
    My screen just cracked diagonally from a 50 cm height fall ! Is oneplus is just that weak? What to do now? Any suggestions?
  2. the_o2
    OnePlus 9 Series Expert Community Expert May 20, 2018
  3. leo98918
    Ice Cream Sandwich May 20, 2018
    leo98918 , May 20, 2018 :
    The device is not "weak". Glass is glass, no matter what treatment it has received, it will never be indestructible.
  4. powerofred
    Jelly Bean May 20, 2018
    powerofred , May 20, 2018 :
    My OnePlus 5's screen broke from dropping at a height of around 20-25 cms. Glass is breakable, it's durability depends upon many factors.
    Aman Singh gurjar likes this.
  5. santhosh311983
    Honeycomb May 20, 2018
  6. PTuT
    PTuT , May 20, 2018 :
    And, did you have a tempered glass protector installed? Even with these protections, nothing is 100% proof.
    You have several options...have it repaired, repair it yourself, or live with it if display and touch screen digitizer are in working order.
  7. Siddharth.Life
    Gingerbread May 20, 2018
    Siddharth.Life , May 20, 2018 :
    weak? are you for real? I don't think there is an option for you to change the digitizer hence buy the screen from ********** if you're a DIY guy or go to the service center.
  8. ghostofcain
    Marshmallow May 20, 2018
    ghostofcain , May 20, 2018 :
    Well it lasted nearly two years so it ain't that fragile. As for what to do now, as I see it you have two options, get it repaired or don't.
    Aman Singh gurjar and Nick 59 like this.
  9. bojantomic
    bojantomic , May 20, 2018 :
    If you drop it on a carpet it won't break probably, but if you drop it on concrete, stone or tiles, it probably will break.
  10. Dr.SRJ
    Donut May 20, 2018
    Dr.SRJ , May 20, 2018 :
    A friend of mine did the same mistake twice in breaking...so replacing the screen only option left else go for op6
  11. ghostofcain
    Marshmallow May 21, 2018
    ghostofcain , May 21, 2018 :
    [Heresy]There are other phone companies you know[/Heresy]
