Gmail has no led notifications.
  1. antmex Cupcake Jan 13, 2018
    antmex, Jan 13, 2018 :
    After Oreo update the Oneplus 5 has no led notifications when received a new email in Gmail app.
    In other email apps, led notifications working properly.
  2. kkuderko Cupcake Apr 11, 2018
    kkuderko, Apr 11, 2018 :
    any luck on fixing this? I've got the same issue. OP support suggested factory reset...
  3. kkuderko Cupcake Apr 12, 2018
    kkuderko, Apr 12, 2018 :
    update: discovered when you disable sound for notifications - the LED stops working. When you assign a sound to notifications - the LED is working again.
    OP support advised it's a normal behaviour so I LOL'ed them :)
    Anyway, for now I work around this by:
    1. download the 1 second of silence mp3, i.e. https://github.com/anars/blank-audio
    2. upload this to the phone Ringtones folder (used Android File Transfer app)
    3. Settings > Notifications > Sound & Vibration > Default notification ring tone > Local ring tone > 1-second-of-silence.mp3
    4. Outlook > Options > Notifications > New Email sound > Default notification sound > OK
    5. Bang! no annoying email sounds but LED is blinking
