8
Gmail not pushing notification on op 9 pro via OnePlus 9 Pro
  1. raghvendras63
    Eclair Apr 16, 2021
  2. the_o2
    OnePlus 9 Series Expert Community Expert Apr 16, 2021
    Best Answer
    the_o2 , Apr 16, 2021 :
    Press and hold the gmail app
    Click on app info
    Advance
    Battery
    Set it to don't optimise
    Force stop the app and restart your phone once and see if it makes any difference.
    rHITkM., darkarvan, Sun90 and 2 others like this.
  3. Steili
    Donut Apr 17, 2021
    Steili , Apr 17, 2021 :
    I have the same issue with Gmail.
    Worked a couple of days as I got the new phone but now it doesn't work.
    Battery optimization is turned off.
    As many users have reported this problem I think it has to be solved by Oneplus.
    Joel Hollenbeck and deezid like this.
  4. dao2009
    Cupcake Apr 18, 2021
    dao2009 , Apr 18, 2021 :
    Same issue here as well.
    Battery optimization off.
    All notifications correctly set.
    I have read somewhere it is an issue but no ETA on a fix
  5. raghvendras63
    Eclair Apr 18, 2021
    raghvendras63 , via OnePlus 9 Pro , Apr 18, 2021 :
    Yes it worked
    the_o2 likes this.
  6. Steili
    Donut Apr 18, 2021
    Steili , Apr 18, 2021 :
    It might work, but only for a couple of hours or days. Then it stops working again.
  7. RINU_SHALIK
  8. dracarys6k
    Gingerbread Apr 18, 2021
    dracarys6k , via OnePlus 9 Pro , Apr 18, 2021 :
    Got thiese steps through op support
    1. Settings > Apps and Notifications > See all > Play services > Clear Storage
    2. Settings > System > Reset options > Reset app preferences
    3. Update all the GMS apps and check
    4. Wipe cache reboot through recovery mode.
    - Power off your device.
    - Press the power key + volume down for a few seconds.
    - Select English.
    - Tap on Wipe data and cache.
    - Tap on Wipe cache again (Important only wipe cache)
    - Tap on Yes to confirm.
    - Wait for the wipe process to complete.
    - Reboot the phone.
  9. MomZo
    Honeycomb May 12, 2021
    MomZo , May 12, 2021 :
    I have exactly the same issue about Gmail notifications not received.
    Sync is enabled, all notifications are enabled, battery optimization is set to "not optimized" for Gmail, there is no restriction defined for the App, I cleared data and cache...
    It really looks like a proper bug, from Oxygen OS, Android 11 or Gmail itself.
    I raised a ticket on OnePlus side and hope a solution will come soon from any of these parties.
    O1608122191624 likes this.
  10. F1620442297296
    Cupcake May 12, 2021
    F1620442297296 , via OnePlus 9 Pro , May 12, 2021 :
    I got the same issue here with my Gmail notification. I have tried all the options. It didn't help. Hi OnePlus system, please help on this matter. Looks like it's a very common issue with maximum users. It needs to be fixed.
  11. Bronkos
    Froyo May 12, 2021
    Bronkos , via OnePlus 9 Pro , May 12, 2021 :
    This has to be fixed guys! I tried every possible suggestion but there is no permanent fix. After some hours/days the gmail sync gets stuck.
  12. Bruno Lugnani
    Ice Cream Sandwich May 12, 2021
    Bruno Lugnani , via OnePlus 9 Pro , May 12, 2021 :
    I had this problem with my 8 Pro, now that I own 9 Pro I have solved it with Fairemail and notifications for my 4 different accounts including Gmail arrive immediately
    MomZo likes this.
  13. AbandonedTrolley
    Jelly Bean May 12, 2021
  14. #14
  15. Ghazala.Yasmeen
    OnePlus Bug Hunter Staff Member May 12, 2021
    Ghazala.Yasmeen , May 12, 2021 :
    We may have to check this further and have contacted you through personal conversation.
    Regards,
    Ghazala
  16. Ghazala.Yasmeen
    We have got in touch with you through personal message, request you to check for the same.
    Regards,
    Ghazala
  17. mixman
    Eclair May 12, 2021
    mixman , May 12, 2021 :
    Same issue. Default settings and phone setup from scratch without any migration tools. Tried toggling sync on/off without effect. I have personal and work profile in use.
    I've received a notification at the same time when opening Gmail itself, for something a day old...
  18. MomZo
    I ended up installing Spark. Notifications for my 3 mailboxes are now pushed nearly instantly.
    My guess is this bug is coming from Android 11 (or its implementation in Oxygen OS), as GMail always worked perfectly with my good old OnePlus 6T running Android 10.
    If it is corrected in a coming update, and if I am not hooked by Spark, I might come back to GMail later.
  19. cocoamonster
    Cupcake May 13, 2021
    cocoamonster , via OnePlus 9 Pro , May 13, 2021 :
    I tried all the things you guys mentioned above, and I'm still not getting notifications.
    It is really amazing that such a small thing can't even be fixed with four updates. This is my first OnePlus phone and to be honest, I won't recommend it to any of my friends.
    Using a phone shouldn't require a typical user to dive into those settings, this is the most basic function.
    Tim Simonds likes this.
  20. DominusMathias
    Cupcake May 15, 2021
