5
Gmail notifications
  1. iacovos1989
    Donut Nov 27, 2017
    iacovos1989 , Nov 27, 2017 :
    I am not getting any notifications for new emails and it's a bit worrying as I got used to having this and it's a feature I sort of need. Can someone tell me how to make this work?
    On the app, the settings have notifications enabled so I'm not sure where the problem is.
  2. GuitarBart
    Jelly Bean Nov 27, 2017
  3. TheMystic
    Lollipop Nov 27, 2017
    TheMystic , Nov 27, 2017 :
    have you enabled notification for every message?
    have you excluded Gmail from battery optimisation?
  4. MentalDraco
    Marshmallow Nov 27, 2017
    MentalDraco , Nov 27, 2017 :
    i have hear of this from the OP 5 if you look for it there is a post like 100 pages long if you want to read it, I am happy i have no notifications for it, else it would drive me mad since i get a not of e-mails.
  5. loveyou660909
    Cupcake Nov 27, 2017
  6. iacovos1989
    Donut Nov 27, 2017
    Kokerakos likes this.
  7. iacovos1989
    Donut Nov 27, 2017
    this seems to do the trick. Have to add notifications to each type of inbox to work
    kartikeyainfo52 likes this.
  8. TheMystic
    hope you don't get duplicate notifications because of that.
  9. MirzaNisarBaig
    Froyo Nov 27, 2017
    MirzaNisarBaig , Nov 27, 2017 :
    Go into phone settings then select "accounts" and then select three dots at top right side corner and press "Auto-Sync data" and that's it. Close all apps and refresh. You'll start receiving notifications again.
  10. iacovos1989
    Donut Dec 3, 2017
    iacovos1989 , Dec 3, 2017 :
    No duplicate notifications.
    Biggest issue is that Gmail only shows notifications when I'm connected with wi-fi and that's not really convenient as I obviously need to have this feature with mobile data.
    Auto-sync is on.
  11. Waka_Yama
    Ice Cream Sandwich Dec 9, 2017
    Waka_Yama , Dec 9, 2017 :
    Pushing this threat cause i have the same problems.
    I find it rather unusal that Gmail doesn't show up in the "excluded from battery optimisation" list and i can't add it due to it's not availeable.
    Any ideas how to solve this?
  12. phbbonn
    Cupcake Jan 8, 2018
    phbbonn , Jan 8, 2018 :
    +1 on this for me
    It's really sad that there is no response from oneplus on this in any of the threads mentioning this issue. This is a very unconvenient situation, where no workaround seems to exist.
  13. Waka_Yama
    Ice Cream Sandwich Jan 8, 2018
    Waka_Yama , Jan 8, 2018 :
    after some weeks with the op5t it seems that I found a solution for my needs. I disabled in developer settings the standby-modus.
    in the current versions I tested (4.7.6 and Beta) I had no problems with notifications with this setting. even the impact on battery seems to be acceptable.
    I still would like to exclude Gmail from battery optimization.
    But to be honest, it doesn't bother anymore. my previous used Mate10 gave me a bigger headache about this matter. there wasn't a way to disable anything like the strict standby
  14. Nevermindtheneversettle
    Cupcake Jan 8, 2018
  15. Spigkos
    Gingerbread Jan 8, 2018
  16. phbbonn
    Cupcake Jan 8, 2018
    Thanks for the hint, i will give it a try.
    Like you I would prefer a proper solution as well. Especially because it was a function working properly before the last update.
  17. phbbonn
    Cupcake Jan 9, 2018
    phbbonn , Jan 9, 2018 :
    Sadly it had no effect on my 3t with oxygen os 5.0.1.
  18. iacovos1989
    Donut Apr 28, 2018
  19. Ajit_suryawanshi
    Gingerbread Apr 28, 2018
    Ajit_suryawanshi , Apr 28, 2018 :
    m also facing same issue but i think its not phone issue its your gmail account just try to add your friends gmail account and see......also please try google assistant and say navigate me to pune?...what is result is it shown direct navigation or shown google results please tell?...
  20. Centaurus
    Froyo Jul 24, 2018
