Going directly from CM 11 44S to CM 12S
  1. soonermagic
    Gingerbread Apr 16, 2015
    soonermagic , Apr 16, 2015 :
    Like many, I have held off upgrading to 5Q due to all of the reported issues. I know it's still early, but the 12S feedback seems relatively positive so I am thinking of updating.
    What are the issues (if any) with moving straight from 44 to 12? And if I do not update to 5Q, will I still receive an OTA for 12S?
    Thanks in advance.
  2. achal1012
    Froyo Apr 16, 2015
    achal1012 , Apr 16, 2015 :
    you can directly flash the zip from recovery if you like. Otherwise via OTA you will get 5Q update and then the 12S update.
    soonermagic likes this.
  3. soonermagic
    Thx @achal1012. I'm not rooted so it sounds like I should go ahead with the 5Q update and then wait for 12S? I am hoping to avoid (or at least minimize) the pain & suffering of 5Q.
  4. achal1012
    Froyo Apr 16, 2015
    You dont need custom recovery to flash this update. You can use the stock CM recovery which is already there.
    Just get the zip file of update put in your internal storage>> Switch off OPO >> press and hold vol down+ power until it vibrates >> (you should be in recovery now) >> navigate(use volume keys) to " Wipe cache partition" press power button(once) to select it>> then select "apply update" >> then "choose from internal..." >> "0/" >> and find and select your zip
    Enjoy the cm 12S :)
  5. soonermagic
  6. soonermagic
    And just to confirm....
    The 12S download thread says to ..."make sure you are on CM11S 05Q (rooted or stock, both will work)" But you're telling me I can bypass 05Q and go from 44S to 12S? Any risks?
  7. achal1012
    Froyo Apr 16, 2015
    I updated one friend's opo my self. But if you have doubts just update to 05Q and then go to 12S! We don't want a bricked phone. So its better to be sure and safe than sorry. Update to 05Q and then 12S
  8. soonermagic
