Good router suggestion
  1. arashhsh
    Honeycomb May 12, 2015
    arashhsh , May 12, 2015 :
    Hi There,
    I recently upgraded my internetspeed from 30mb/s to 120 mb/s however I don't have the speeds and connectivity range I should have. So I cant make the most of my internetspeed ... Kinda useless upgrade..
    My question is now, what is a good router which supports a 2.4ghz freq as well as a 5ghz freq. I want it to be able to give me high speeds and a wide connectivity range.
    Im not a rich Guy so please don't Come up with 300€ routers.
    Thanks in advance
  2. sidlittlefield
    KitKat May 12, 2015
    sidlittlefield , May 12, 2015 :
    Asus RT-AC68U Dual-band Wireless-AC1900 Gigabit Router
  3. DaxNagtegaal
    Marshmallow May 12, 2015
    DaxNagtegaal , May 12, 2015 :
    Bump because I'm also looking for a cheap but good router that will do dual band and handle a 200Mb/s connection
  4. DaxNagtegaal
    lmfao 160 euros nope nope nope
    arashhsh likes this.
  5. Who.is
    Who.is , May 12, 2015 :
    TPLINK WDR 4300
  6. Deactivated User
    May 12, 2015
    maniatiko, BradRDavis and kp1234 like this.
  7. prstorero
    Jelly Bean May 12, 2015
    itechy21 and arashhsh like this.
  8. kp1234
    Community Veteran May 12, 2015
    kp1234 , May 12, 2015 :
    Well if you're paying for 120mbps internet might as well pig out on the router..
    bestlands and Dr. Indest like this.
  9. Walkin_mn
    Walkin_mn , May 12, 2015 :
    I can't recommend one in particular nut look for ac routers with more than 3 antennas, those would give you directional signal which improves your reception wherever you are.
  10. Deactivated User
    May 12, 2015
    kp1234 likes this.
  11. sidlittlefield
    KitKat May 12, 2015
    DaxNagtegaal likes this.
  12. DaxNagtegaal
    Damn you US people... Tmobile does nothing cool over here
    bestlands likes this.
  13. DaxNagtegaal
    Nah nah that isn't how it works WiFi, TV and Phone are in one bundle it's actually not that expensive
    kp1234 and arashhsh like this.
  14. Deactivated User
    May 12, 2015
  15. arashhsh
    Well in the netherlands it's not that expensive I Just pay 10€ more to upgrade from 30 to 120
    kp1234 likes this.
  16. arashhsh
    You are right my friend
  17. sidlittlefield
    KitKat May 12, 2015
    It's just one of the perks of trying to take over the world.
  18. DaxNagtegaal
    Good luck
    sidlittlefield likes this.
  19. arashhsh
    I don't have so much to spend bro 180 is a lot for me. No shit I have an opo *cries silently* thank you for your suggestion, will note in case I have some extra to spend
  20. Deactivated User
    May 12, 2015
    addam likes this.
