Good shops for repairing OnePlus phones via OnePlus 7
  1. FibzMatt
    Cupcake Jan 4, 2021
    FibzMatt , via OnePlus 7 , Jan 4, 2021 :
    Does anyone know good repair shops for out of warranty OnePlus phones in Ahmedabad, Gujarat. My phone's bluetooth and wifi IC is damaged and OnePlus service centres will only change the whole main board which will cost me 19k which I can't afford to spare. So looking for some shops which can do it at a lower cost.
    AbhilashSaikia likes this.
  2. camohan
    Moderator Moderator Jan 4, 2021
    camohan , Jan 4, 2021 :
    Hi there, thread moved to India Section. Did you try using google maps to identify mobile repair shops near your location?
    Tobikage likes this.
  3. FibzMatt
    Cupcake Jan 4, 2021
    Yes tried many shops and they have declined as they don't have the IC, can I know which IC no or something to be used in it so I can try to order it globally somewhere.
  4. Tobikage
    Nougat Jan 4, 2021
    Tobikage , Jan 4, 2021 :
    Check a teardown video or guide and find the relevant part.
    Tip : Your local shops do not have the capacity / equipment required to replace these parts on the motherboard.
    Shailender Sharma likes this.
  5. OALEXANDER
    Assistant Head Moderator Assistant Head Moderator Jan 4, 2021
    OALEXANDER , Jan 4, 2021 :
    Not sure if you can get spare parts from local shops.
    Will still recommend going through official route
    Visit the center here if and find your estimate.
    OnePlus Exclusive Service Centre - Shree Vardhama,12-adarsh society, opposite city centre swastik cross road, Chimanlal Girdharlal Rd, Navrangpura, Ahmedabad, Gujarat 380009
    Show on map
    Contact No:
    079 4039 1797
    Shailender Sharma and Tobikage like this.
  6. FibzMatt
    Cupcake Jan 4, 2021
    I have already visited here where estimated 19k was to be paid for the main board.
  7. Shailender Sharma
    Marshmallow Jan 4, 2021
    OALEXANDER and Tobikage like this.
  8. FibzMatt
    Cupcake Jan 4, 2021
  9. OALEXANDER
    Spare parts will be expensive when you look at break up of the parts.
    Yes I read in your first post itself and still recommend to go thru getting the official parts. If not yes you can check on the web the availability of the parts from third party.
    Or get a refurbished phone
