Good spare/replacement charger UK
  1. takkischitt
    Froyo Oct 22, 2014
    takkischitt , Oct 22, 2014 :
    Hi folks
    Thought I'd post this as it should help plenty of folks out.
    If you need a replacement or a spare, this should do the trick. It's a 2.1A charger with lead. It's meant to be for Tesco's own hudl devices, but as we all know, it will suit any device that accepts micro USB. Being sold by a 'respectable' UK retailer, it's is probably a bit more safe than some of the cheap versions you may find on eBay etc. It has the safety marks on the label anyway, so it will have passed UK/European safety tests.
    http://www.tesco.com/direct/hudl-micro-usb-power-charger/356-0645.prd
    Hope this helps!
  2. Hanson Lee
    Marshmallow Oct 22, 2014
  3. Cboyd104
    Ice Cream Sandwich Oct 22, 2014
    Cboyd104 , Oct 22, 2014 :
    i bought a Blackberry mini usb charger, 2.1A and with a 6 foot cable. came with worldwide plug adapters which slide into the main housing.
  4. SizeOne
    Honeycomb Oct 22, 2014
  5. takkischitt
    Froyo Oct 22, 2014
  6. aalau
    aalau , Oct 22, 2014 :
    Nice one.
    Can try this fused converter if you want to keep the original OPO charger.
    digitaldr likes this.
  7. takkischitt
    Froyo Oct 22, 2014
  8. aalau
    takkischitt likes this.
  9. takkischitt
    Froyo Oct 22, 2014
  10. aalau
  11. digitaldr
    Gingerbread Oct 22, 2014
