Kaustuv85 , via OnePlus Nord , Sep 20, 2020 : Google assistant starts automatically without saying "hey google". Whenever i am having conversation with anyone, google assistant automatically starts and records my conversation and start searching them. It's really annoying and only seen this kind of issue in cheaper phones never expect such things in best phone like ONE PLUS. This is my first time using ONE PLUS Phone . Please fixed this issue ASAP
DinethIrusha , via OnePlus Nord , Sep 20, 2020 : You can always disable Google Assistant if you don't like if
Neerajan , via OnePlus 8 , Sep 20, 2020 : I think the issue is with Google assistant, and not with OnePlus. Just go through this link . Try clearing the cache for the google app, and uninstall the updates. Then try reinstalling them and restart your device, it could help with your situation. If nothing works it is better to disable google assistant if you're not using it frequently. If you're using Google assistant frequently, then it is better to contact the google app developers directly via email provided in the play store.
