117
Theme Google Camera Ports for OnePlus 3/T, 5/T, 6/T and 7/Pro
  1. Ray_ofLight
    Gingerbread Aug 29, 2019
    Ray_ofLight , Aug 29, 2019 :
    I've downloaded and installed the latest Gcam apk on my OnePlus 5T, but when I open the Gcam app I am notified with this message "camera keeps stopping".
    Is there any setting I need to do?
  2. Manu Sangeeth
    Froyo Aug 29, 2019
    Manu Sangeeth , Aug 29, 2019 :
    try to install older versions which are a bit more stable.
  3. Ray_ofLight
    Thanks for the advice. Will try.
  4. Goggeboy
    Honeycomb Sep 12, 2019 at 7:26 PM
  5. Bagonwagons
    Cupcake Sep 15, 2019 at 6:49 PM
    Bagonwagons , Sep 15, 2019 at 6:49 PM :
    Anyone have experience with gcam on Android 10 beta? Some versions are okay, some are laggy..it takes forever to process hdr+ photos, not to mention photo sphere not working...don't know if I should roll back to Android Pie or is there some solution to get gcam working properly on Android 10 beta..
  6. Ray_ofLight
    Gingerbread Sep 15, 2019 at 10:18 PM
  7. Goggeboy
    Honeycomb Sep 16, 2019 at 3:10 PM
    Goggeboy , Sep 16, 2019 at 3:10 PM :
    At least OP 7/7 Pro are compatible. There is a link to config files, where you can se compatible phones
  8. Goggeboy
    Honeycomb Sep 16, 2019 at 3:13 PM
    Goggeboy , Sep 16, 2019 at 3:13 PM :
    And there is a new versio of beta app. It works also fine.
    Use this method always when you install the app.
    1. Go Settings- Apps
    2. Force quit the app
    3. Clear storage
    4. Uninstall the old app
    5. Install the new app
    6. Reboot your phone
    7. Use your new app and take a photo
  9. Goggeboy
    Honeycomb Sep 16, 2019 at 5:25 PM
    Goggeboy , Sep 16, 2019 at 5:25 PM :
    You can find config files for OP 6/6T and 7/7 Pro
  10. Ray_ofLight
    Gingerbread Sep 16, 2019 at 5:55 PM
    Ray_ofLight , Sep 16, 2019 at 5:55 PM :
    I've downloaded the link you provided on my 5T, the back camera is all good however the front camera pictures are having purple lines as per attached picture. Could you suggest me a solution?
  11. Goggeboy
    Honeycomb Sep 17, 2019 at 4:32 AM
    Goggeboy , Sep 17, 2019 at 4:32 AM :
    Maybe it isn't compatible with 5T because there's no config file for that model?
    But you can try to change the front camera mode. In Camera app More-settings-front camera- try Nexus 5 or 6
  12. F1557606980916
    Cupcake Sep 17, 2019 at 8:53 AM
