100
Theme
Google Camera Ports for OnePlus 3/T, 5/T, 6/T and 7/Pro
  1. tide1109 Honeycomb Jun 15, 2019
    tide1109, Jun 15, 2019 :
    Thanks for the feedback.
    Do you use the config from this page? Is it the 1.6 or 2.0 config?
    The 48 mp resolution is working, right? The resolution of the front camera is limited to 4 mp?
    script likes this.
  2. Goggeboy Honeycomb Jun 15, 2019
    Goggeboy, Jun 15, 2019 :
    No, I'm getting front 4,1 Mpix and back 13 Mpix. Using 1.6 settings
    script likes this.
  3. tide1109 Honeycomb Jun 15, 2019
    Is the 13 mp also the highest option in the Gcam settings? For me the restoring of the config changed the resolution down to 12 mp on my OP6, because the config isn't adapted to version 1.6 by Arnova. I can manually change the resolution back to the default 16.3 mp.
    I add this to the Known Issues.
    script likes this.
  4. Goggeboy Honeycomb Jun 15, 2019
    I get only max. 12 Mpix for back camera
    script likes this.
  5. Goggeboy Honeycomb Jun 15, 2019
    changed to 2.0 configs. Same results
    script likes this.
  6. tide1109 Honeycomb Jun 15, 2019
    I would say, that it is OnePlus's fault. It's probably the same issue as the the one of the front camera. 3rd party apps are getting only the pixel binned picture, that has 12 mp on the rear or 4 mp on the front. The GCam port should now support the 48 mp.
    Thanks for helping.
    script and Goggeboy like this.
  7. KTaylor62 Gingerbread Jun 15, 2019
    KTaylor62, Jun 15, 2019 :
    I'm using the 7 pro and have been having an issue with playground. has anyone figured a way to use this. I've deleted and reinstalled. I've set up configs. I click playground and it just takes me back to the camera.
  8. tide1109 Honeycomb Jun 15, 2019
    Playground has nothing to do with the GCam port itself. You can use it without GCam. So you don't need a special config.
    Do you have ARCore by Google installed?
    Does Playground crash or close by itself?
    Try to give Playground all permissions (storage, camera and microphone) manually.
    You could also try another Playground version (download) or the older AR Stickers, that are mentioned in the Playground post.
    script likes this.
  9. KTaylor62 Gingerbread Jun 15, 2019
    thanks. this one works for me
    script likes this.
  10. bphome Cupcake Jun 16, 2019
    bphome, Jun 16, 2019 :
    I cannot download it, it saids the download link not found. I am using 7 pro, thx.
  11. Goggeboy Honeycomb Jun 16, 2019
    Goggeboy, Jun 16, 2019 :
    Did you use browser? As it mentioned in the first post?
  12. bphome Cupcake Jun 16, 2019
  13. shahi14323 Froyo Jun 17, 2019
  14. tide1109 Honeycomb Jun 17, 2019
  15. bphome Cupcake Jun 17, 2019
  16. dominusomnibus Cupcake Jun 19, 2019
    dominusomnibus, Jun 19, 2019 :
    Quick question: Is there a 100 % working version of the Gcam for the Oneplus 6? If so, which version and config xml? I'm asking because I've not managed to find a fully working version of the camera yet. Thanks.
  17. KTaylor62 Gingerbread Jun 19, 2019
    KTaylor62, Jun 19, 2019 :
    dominusomnibus
    Quick question: Is there a 100 % working version of the Gcam for the Oneplus 6? If so, which version and config xml? I'm asking because I've not managed to find a fully working version of the camera yet. Thanks.​
    you may have to delete and readd the app. i had some issues at one point but that seemed to fix it.
    _zamzury_nuyie_ likes this.
  18. KTaylor62 Gingerbread Jun 19, 2019
    what's not working for you? between arnova and (I don't remember the other popular developer) all functions should be working. I was using it with my 6T and had a really good experience. using it now with my 7 Pro I have everything working.
  19. tide1109 Honeycomb Jun 19, 2019
    tide1109, Jun 19, 2019 :
    Because that I added the disclaimer to uninstall older versions before updating. A clear of the app data would do it too but the install is simpler to understand.
    The Arnova 1.6 version is working fine. I didn't found anything that is not working or causes crashes. It's a 100% working version.
    There are already versions that are based on a newer GCam version by Google, but they shouldn't be as stable as the listed version for now.
    The 100% perfect GCam is not possible because of some limitations by OnePlus. The front camera resolution is only 4 MP and the OP7 main sensor is only accessable at 16 MP. Let's watch if the GCam can use the wide angle and zoom lens on the Pro.
    Besides that the support of GCam is pretty good on OnePlus phones. (I ignore the OP5/T)
  20. Goggeboy Honeycomb Jun 19, 2019
