163
Theme Google Camera Ports for OnePlus 7/T (Pro), 6/T, 5/T and 3/T
  1. G_David_Stephens_IALC
    Cupcake Oct 2, 2019
  2. thevinayjain
    Froyo Oct 15, 2019
  3. Goggeboy
    Honeycomb Oct 16, 2019
    Goggeboy , Oct 16, 2019 :
    Don't know what version you have installed, but at least this version has config file for OP5 https://www.celsoazevedo.com/files/android/google-camera/f/configs-arnova-01/
    Always remember what to do
    1. empty storage for old camera app (GGam)
    2. uninstall old Camera app
    3- install the new one
    4. reboot your phone
    5. choose the right config file
    script likes this.
  4. tide1109
    Ice Cream Sandwich Oct 19, 2019
    tide1109 , via OnePlus 6 , Oct 19, 2019 :
    I added the OnePlus 7T series to the list. The 7 series' version should also work on the 7T series because the use almost the same hardware in terms of SoC and camera sensor.
    I also added a Android 10 compatible version for the OP6/T. Please don't forget the app-data clear after the install. Maybe it's also needed on the OP7(T) series. It's the same GCam port.
    The OP5/T hasn't got the best support for GCam, because OnePlus messed a bit in the camera implementation.
    The version without the fix is a bit older. Maybe the version doesn't work on Android Pie.
    The XDA thread is your best friend. The OP5/T hasn't got the highest priority and the devices are messed up, so it's not worth to me understand the problems without owning a OP5/T. Sorry
    The XDA thread: https://forum.xda-developers.com/oneplus-5/themes/google-camera-hdr-t3655215
    script likes this.
  5. script
    Nougat Moderator Oct 19, 2019
    script , Oct 19, 2019 :
    Thank you so much for keeping your support on such a high level!
  6. Saruf_Ratul
    Froyo Oct 20, 2019
  7. tide1109
    Ice Cream Sandwich Oct 20, 2019
    tide1109 , Oct 20, 2019 :
    Please read the OnePlus 7 series post.
    portable? Do you mean Google Camera Port?
    Saruf_Ratul likes this.
  8. Saruf_Ratul
    Froyo Oct 20, 2019
  9. tide1109
    really? Why do I list it on the for OnePlus 7 Pro post?
    I can't test it, but as far of other recommendations and forum feedback the version should work.
    Where is the problem to test it out? If the app would crash you know the version doesn't work.
  10. Goggeboy
    Honeycomb Oct 20, 2019
    Goggeboy , Oct 20, 2019 :
    @tide1109 Do you think, that this config file Arnova-6.2-Fiz-MCG-Lib-1.0. works the best?
  11. tide1109
  12. Goggeboy
    Honeycomb Oct 21, 2019
    Goggeboy , Oct 21, 2019 :
    Nope, you're in the wrong thread. This is for photography
  13. Z1560967212438
    Cupcake Oct 25, 2019
  14. tide1109
    Ice Cream Sandwich Oct 25, 2019
    tide1109 , via OnePlus 6 , Oct 25, 2019 :
    Do you mean 'App not installed' ?
    Uninstall all other Google Camera Ports before installing a new one.
  15. jonsteel1974
    jonsteel1974 , via OnePlus 6T , Oct 25, 2019 :
    I've downloaded, cleared app info and rebooted but panorama crashes the app out. anybody any ideas?
    6t android 10 version of app version 2.2.2beta2.190907.0540build-6.2.030
    DjBeNi2 likes this.
  16. tide1109
    I don't know. I have a OP6 without T and the same GCam version. Panorama is working fine for me.
  17. Goggeboy
    Honeycomb Oct 27, 2019
    Goggeboy , Oct 27, 2019 :
    What config file you are using?
  18. Anuraagn_One.Plus_6T
    Eclair Oct 31, 2019
    Anuraagn_One.Plus_6T , Oct 31, 2019 :
    Why can't I open the file for OP6T?
  19. eibcalen
    Cupcake Nov 2, 2019
    eibcalen , Nov 2, 2019 :
    No config file needed for this.
