202
Theme Google Camera Ports for OnePlus 8 (Pro), 7/T (Pro), 6/T, 5/T and 3/T
  1. sudeep
    Donut Apr 7, 2019
    sudeep , Apr 7, 2019 :
    Here is the picture of front camera of G'cam. I could not fix it.
    Back Camera works well. I am using 5T. Can anyone help me please?
  2. v4vamsi
    Ice Cream Sandwich Apr 11, 2019
    script likes this.
  3. MaximusHumus
    Cupcake Apr 13, 2019
  4. tide1109
    Ice Cream Sandwich Apr 13, 2019
    tide1109 , Apr 13, 2019 :
    You need the fix provided in the post for the front camera.
    Thank you!
    Go to the OnePlus 6 post and download and install the version. Go to post #2 in the app (post #3 on the website). OnePlus Forum links to a specific post in a thread are broken.
    script likes this.
  5. MosQa75
    Eclair Apr 14, 2019
    MosQa75 , Apr 14, 2019 :
    Hi guys. I have oneplus 5 (oxygen 8.1.0) and would like to install gcam + do the fix of DOT pattern issue. Is there any other way to fix this issue without root, twrp and magisk? I don't want to do this whole process including phone data loss (due to oem unlock) just because of DOT fix installation.
    I have another question, if I'll have to do this process, can I lock back OEM after rooting, twrp and magisk installation or will it cause the brick of my phone? Thank you.
  6. tide1109
    Ice Cream Sandwich Apr 14, 2019
    tide1109 , Apr 14, 2019 :
    I don't know another way to fix.
    If you lock the bootloader again, then the resets itself too. The fix is now gone.
    If you do it correctly, then the phone won't brick.
    script likes this.
  7. ashirm98
    Donut Apr 21, 2019
    ashirm98 , Apr 21, 2019 :
    Is there a troubleshooting link for OnePlus 5? when I click the link, it keeps going to the OnePlus 3 page.
    I am specifically looking for the fix for the app crashing immediately when opening
  8. Arthurochrome
    Cupcake Apr 27, 2019
    Arthurochrome , Apr 27, 2019 :
    tide1109
    Thank you!
    Go to the OnePlus 6 post and download and install the version. Go to post #2 in the app (post #3 on the website). OnePlus Forum links to a specific post in a thread are broken.​
    hello,
    I have the same problem. I added the XML but in front mode, the photo is all purple. help me please
    @v4vamsi
  9. Arthurochrome
    Cupcake Apr 28, 2019
    Arthurochrome , Apr 28, 2019 :
    tide1109
    Thank you!
    help me please [e]1f62d[/e]
  10. tide1109
    Ice Cream Sandwich Apr 28, 2019
    tide1109 , Apr 28, 2019 :
    So you have a OnePlus 5/5T, right?
    You can try to use the old version (Arnova's v7Beta-Test-9) that may work without a fix or you choose the other version, that needs the external fix to work. The purple picture shows, that the fix is missing.
    So you have to root/install TWRP or use the OnePlus camera app.
    script likes this.
  11. Arthurochrome
    Cupcake Apr 29, 2019
    Arthurochrome , Apr 29, 2019 :
    Thanks.
    I have OP5T.
    I install other version.
    MGC_6.1.021_BSG_Arnova-TlnNeun_Urnyx05-v4.4.apk
    I always have a purple image in front camera. I am not Root. Do you have a solution, do you know the place in the settings to disable the hdr on the front camera ... I find it a shame to disable it. the pictures will be less beautiful.
    thank you in advance.
  12. tide1109
    Ice Cream Sandwich May 3, 2019
    tide1109 , May 3, 2019 :
    I updated the versions for all devices and Playground.
    I added also a disclaimer for the common problems on the OnePlus 5/T and that the fix is required to fix it.
    Top Shot seems to work on the standard Google Photos version, so removed the part. It's working fine for some tests, but the resolution limitations are still present.
    If there are OnePlus 7 (Pro) versions available in the future, I will add them to the collection. By the way I'm at the Launch Event in London.
    script likes this.
  13. S1550811358892
    Donut May 4, 2019
  14. tide1109
    Ice Cream Sandwich May 4, 2019
    tide1109 , May 4, 2019 :
    You have to open the download link with your browser and not with the community app.
    Click on the download link (direct) and then tap the 3 dots and open with browser.
    S1550811358892 and script like this.
  15. shahi14323
    Gingerbread May 10, 2019
  16. script
    Nougat Moderator May 10, 2019
  17. Henriko Magnifico 2
    Donut May 22, 2019
  18. Cravers
    Cupcake May 23, 2019
    Cravers , May 23, 2019 :
    I'm getting this aswell on my 5T, running the latest version (9.0.5 OxygenOS)
  19. Srinidha
    Donut May 30, 2019
    Srinidha , May 30, 2019 :
    Is the Pro mode (advanced mode) available in gcam mod for One plus 6T....
    I'm using gcam version 6.2.024...
    It says it has pro mode feature....but for me it only shows the normal mode even switching on the advance mode in settings...
    Anyone who know which version of gcam has advanced mode working or how to make advanced mode work in 6T with current version please help ..
    Thanks in advance.
  20. Muhammad_Kashif_bahl
    Gingerbread May 30, 2019
