219
Theme Google Camera Ports for OnePlus Nord, 8 (Pro), 7/T (Pro), 6/T, ...
  1. Goggeboy
    Honeycomb Dec 4, 2019
    Goggeboy , Dec 4, 2019 :
    As you can read above, it doesn't work on OP 6
  2. Goggeboy
  3. Hemangb2
    Honeycomb Dec 9, 2019
  4. C1574864214510
    Donut Dec 9, 2019
    tide1109 and Goggeboy like this.
  5. Goggeboy
    Goggeboy , Dec 9, 2019 :
    Don't use mobile forum app, use browser
  6. tide1109
    Jelly Bean Dec 9, 2019
    tide1109 , via OnePlus 6 , Dec 9, 2019 :
    Downloading files with the Community app (V3.2.2) now works half-baked.
    When I press on the download link of a GCam version (apk file download), my browser opens with the download request. But when I want to download a config (xml), I will stuck in the blank Community webview.
    As I said, it's half-baked.
    At least no no more "download not working" comments. The config isn't the most important part.
    I'm on the beta channel in the Play Store, so it still take some until it arrives on all devices.
    Thanks for confirming the right chosen GCam version. Your's is newer version, but it's the same developer.
    I update to this version in a moment.
    This version does still not work on the OnePlus 6 series! It's only for the 7 Series.
    C1574864214510 and Goggeboy like this.
  7. Hemangb2
    Honeycomb Dec 10, 2019
    Hemangb2 , via OnePlus 6T , Dec 10, 2019 :
    Cannot link it to browser with a long touch, nor there are options for copying text.. all I can get is this error..
  8. Goggeboy
    Hemangb2 likes this.
  9. tide1109
    Jelly Bean Dec 10, 2019
    tide1109 , via OnePlus 6 , Dec 10, 2019 :
    That is the issue I talk about. You can't copy the link by long pressing.
    Go to the 3 dots, press on share and the select your browser. You can also copy the link (Android 10+) and paste it in your browser.
    Now you have thread opened in the browser.
  10. Hemangb2
    Honeycomb Dec 11, 2019
  11. tide1109
    Jelly Bean Dec 14, 2019
    tide1109 , via OnePlus 6 , Dec 14, 2019 :
    A GCam 7.2 version for the OnePlus 6 series is out.
    The version should work on Android 9 too.
    I already added this version to the post of the device.
    script likes this.
  12. Ray_ofLight
    KitKat Dec 14, 2019
    Ray_ofLight , Dec 14, 2019 :
    Would this work on 5T as well?
  13. tide1109
    tide1109 , Dec 14, 2019 :
    The version shouldn't work on the 5T or earlier. Before this version the GCam mod from Urnyx was Snapdragon 855(+) exclusive. The SD845 support is new.
    I don't think that it supports the SD835 or earlier. Maybe the OnePlus 5T is incompatible for other reasons too.
    Feel free to test anyway. I the GCam version crashes, it's incompatible.
    Ray_ofLight likes this.
  14. Ray_ofLight
    KitKat Dec 17, 2019
    Ray_ofLight , Dec 17, 2019 :
    I have tried several versions of Gcam app but the constant is that front camera has green tinted pictures, the back camera is alright. I have even applied the fixes but still front camera green tint appears. Any solutions to this?
  15. Goggeboy
    Honeycomb Dec 17, 2019
  16. Ray_ofLight
    KitKat Dec 17, 2019
    Goggeboy likes this.
  17. Vaibhav_Jain_24
    Donut Dec 17, 2019
  18. Hemangb2
    Honeycomb Dec 19, 2019
    Hemangb2 , via OnePlus 6T , Dec 19, 2019 :
    same is happening to me..
  19. Ray_ofLight
    KitKat Dec 19, 2019
  20. Sree92
    Eclair Dec 25, 2019
