219
Theme Google Camera Ports for OnePlus Nord, 8 (Pro), 7/T (Pro), 6/T, ...
  1. Goggeboy
    Honeycomb Dec 26, 2019
  2. Saidur Rahman Emon
    Eclair Jan 1, 2020
    Opaida1985 likes this.
  3. ZorroKenpachi
    Honeycomb Jan 17, 2020
    ZorroKenpachi , via OnePlus 6 , Jan 17, 2020 :
    astrophotography is not working .I am using Op6 , put the camera stable for few minutes in night site but astrophotography is not enabled. what to do?
  4. ZorroKenpachi
  5. Opaida1985 likes this.
  6. rarog
    Assistant Head Moderator Assistant Head Moderator Jan 20, 2020
    rarog , Jan 20, 2020 :
    If they still have the same app id, then it won't work.
  7. GaganGodiwal
    Donut Jan 20, 2020
  8. coolraghav
    Donut Jan 20, 2020
  9. GaganGodiwal
    Donut Jan 21, 2020
    GaganGodiwal , via OnePlus 7T , Jan 21, 2020 :
    now it works with only main camera.
    if I get any update I will post.
  10. Z1576455675248
    Cupcake Jan 21, 2020
  11. GaganGodiwal
    Donut Jan 21, 2020
    it works without root on my 7T.
  12. Z1576455675248
  13. GaganGodiwal
    Donut Jan 21, 2020
  14. Z1576455675248
    Z1576455675248 , Jan 21, 2020 :
    U.S, did clean install and everything. Have an unrooted OnePlus 7t TMobile on the latest version.
  15. GaganGodiwal
    Donut Jan 21, 2020
    May be because of different markets GCAM is not working on yours 7t.
    I am from India.
  16. Z1576455675248
    Guess that could be the reason. Yeah I tired everything.
  17. RobbM
    Gingerbread Jan 21, 2020
    RobbM , Jan 21, 2020 :
    If you join this telegram group you'll find every GCam related for the 7 / 7T / 7T PRO.
    There are recommended versions on the pinned post.
    I'm using the URNYX05 (7.2) Build 2.1 version with the 'Vivid Colours' XML file.
    https://t.me/gcamOP7
    *EDIT*
    Root is not required for GCam to work nor does it matter on which region the phone is purchased. The only reason root would be required is if you want to use all 3 camera modules (Wide/Telephoto).
    Cosmos_NT likes this.
  18. Z1576455675248
    I was reading around and noticed other people are having the same issue. But thanks again for your help!
  19. DrunkNigga
    Cupcake Jan 22, 2020
    DrunkNigga , Jan 22, 2020 :
    My camera isn't opening, but video is getting recorded
  20. rajesh.machadath
    Cupcake Jan 26, 2020
    rajesh.machadath , Jan 26, 2020 :
    I can't enable rear camera switch icons.( in advanced - rearcam switch) when enable wide angle switch. it's crashing)
