215
Theme Google Camera Ports for OnePlus Nord, 8 (Pro), 7/T (Pro), 6/T, ...
  1. J1574069104216
    Cupcake Jan 26, 2020
  2. PercyF
    Donut Jan 31, 2020
  3. r_mjr
    Cupcake Feb 3, 2020
  4. W1579984487133
    Cupcake Feb 4, 2020
    W1579984487133 , Feb 4, 2020 :
    don't you think that in OP 7T, the Gcam version 6.1 takes more defined pictures than the latest version 7.2?
  5. K1580819773225
    Cupcake Feb 4, 2020
    K1580819773225 , Feb 4, 2020 :
    in our community links are genuine or not because I was worrying some phone haking apps. plz suggest.
  6. GaganGodiwal
    Donut Feb 11, 2020
  7. SkypirateDE
    Donut Feb 11, 2020
    SkypirateDE , via OnePlus 7T Pro , Feb 11, 2020 :
    yes i own a 7T Pro and use GCam Urnyx05 with Hooolm V6.xml (great results at day, twilight and night). you have to turn off HDR for faces and selfies for nice skin also works Arnova 7.2 and Burial 7.2 without XML. you can't use zoom and telelense but it works very well with the mainlense.
  8. SkypirateDE
    Donut Feb 11, 2020
    Rashid_mjr likes this.
  9. PercyF
    Donut Feb 11, 2020
    PercyF , via OnePlus 7T Pro , Feb 11, 2020 :
    can you please share the apk and config file please
  10. SkypirateDE
    Donut Feb 11, 2020
    arnav3105 and PercyF like this.
  11. SubhashNayak
    Honeycomb Feb 27, 2020
  12. Q1577535090743
    Cupcake Feb 29, 2020
  13. Goggeboy
    Honeycomb Mar 1, 2020
    Goggeboy , Mar 1, 2020 :
    Stopped using these GCam ports, because OP 7T own camera is good enough and everything works
  14. tide1109
    Jelly Bean Mar 1, 2020
    tide1109 , via OnePlus 6 , Mar 1, 2020 :
    Most of the times I use the OnePlus Camera too. The pictures are good enough and the OP Camera is more convenient. I can use it while the phone is locked and it's stable.
    When it's dark I often use the GCam's Night Sight. Sometimes when zooming is needed I try GCam for Super Res Zoom.
    I try to update the thread in the next days.
  15. Goggeboy
  16. Goggeboy
    But with the newest CGam app you have to root your phone. Because wide lens and 0.6 zoom options doesn't work without that
  17. tide1109
    Jelly Bean Mar 5, 2020
    tide1109 , via OnePlus 6 , Mar 5, 2020 :
    I added a new version for OnePlus 6 and 7 devices.
    It's this version, but Motion Photo does not work/exist on my OnePlus 6. Is it different on the 7 Series?
    So the wide angle and tele lens works in OnePlus phones (with root)? Is directly working with root enabled or is other change like a lib needed?
    I created an idea on the IDEA contest about the GCam. It's more about the camera implementation that helps GCam. So that should hopefully fix the resolution problem and fix the wide angle and tele lens.
    Feel free to support it, if you like the Google Camera:
    https://www.oneplus.com/de/communityideas#/detail?threadId=1192277
    script and Goggeboy like this.
  18. SubhashNayak
    Honeycomb Mar 6, 2020
    SubhashNayak , via OnePlus 7T Pro , Mar 6, 2020 :
    Motion photo isn't working on 7T Pro as well
  19. Deactivated User
    Mar 8, 2020
  20. Goggeboy
    Honeycomb Mar 10, 2020
    Goggeboy , Mar 10, 2020 :
    Yes, you have to install the magisk module to get that working.
