216
Theme Google Camera Ports for OnePlus Nord, 8 (Pro), 7/T (Pro), 6/T, ...
  1. Deactivated User
    Mar 10, 2020
    PlusUn likes this.
  2. Deactivated User
    Mar 10, 2020
  3. Antriksh Mutha
    Cupcake Mar 13, 2020
    Antriksh Mutha , via OnePlus 3T , Mar 13, 2020 :
    I tried installing but it's showing error of app not installed.plz help
  4. tide1109
    Jelly Bean Mar 13, 2020
    tide1109 , via OnePlus 6 , Mar 13, 2020 :
    Do you have any other GCam version installed? Uninstall it.
    The package installer probably said: Do you want to update the app?
  5. Deactivated User
    Mar 13, 2020
  6. tide1109
    Goggeboy, script and Deactivated User like this.
  7. Deactivated User
    Mar 13, 2020
    Soumya Kanti mandal likes this.
  8. Kaustubh Agrawal
    Cupcake Mar 20, 2020
  9. tide1109
    Jelly Bean Mar 20, 2020
    tide1109 , via OnePlus 6 , Mar 20, 2020 :
    Yes, it's working.
    Make sure that it's activated in the quick settings.
  10. Kaustubh Agrawal
    Kaustubh Agrawal , Mar 20, 2020 :
    The timer doesn't stop..and if you stop it yourself the image doesn't get saved.
  11. tide1109
    It's working perfectly fine on my OnePlus 6.
    Do you use the latest recommend version (GCam_5beta10 by Arnova)?
    Which device do you use?
    Goggeboy likes this.
  12. Kaustubh Agrawal
    can you please share some results?
  13. Goggeboy
    Honeycomb Mar 23, 2020
    Goggeboy , Mar 23, 2020 :
    Working also fine on OP 7T
  14. AmanAli786
    Froyo Mar 24, 2020
  15. BOYTOY06
    Eclair Apr 2, 2020
  16. tide1109
    Jelly Bean Apr 5, 2020
    script likes this.
  17. sudeep
    Donut Apr 13, 2020
    sudeep , Apr 13, 2020 :
    I have downloaded Gcam for my OnePlus 5T from the link but that didn't work. The app continue to crash. Besides the selfie camera doesn't work (sample picture attached). I might have been unable to find the proper link or something/some process might have been missed which I didn't come to know.
    Can you please help and guide me to install the Gcam?
    Thank you.
  18. Marydas
    Cupcake Apr 14, 2020
  19. tide1109
    Jelly Bean Apr 16, 2020
    tide1109 , via OnePlus 7T , Apr 16, 2020 :
    The OnePlus 5 and 5T have a very bad Google Camera Port support. The main reason is the bad camera implementation that GCam requires.
    For a proper working GCam you need some additional libraries. The libraries are Magisk Module so you need a unlocked bootloader and Magisk.
    Thanks
    Marydas likes this.
  20. sudeep
    Donut Apr 16, 2020
    sudeep , Apr 16, 2020 :
    Thank You for your advice.
    However I don't want to root my device. Shall I wait for next update (Android 10) which is bound to release on Q2 2020 where I can see some real improvement in the Camera?
    Thank You.
