209
Theme Google Camera Ports for OnePlus Nord, 8 (Pro), 7/T (Pro), 6/T, ...
  1. Viktor Ilie
    Froyo Oct 19, 2020
    Viktor Ilie , via OnePlus 7T , Oct 19, 2020 :
    Well the interface is different here the one that i got, and it restarts the app everytime I choose other camera (wide to macro, or macro to normal,.. etc).
    Anyway i m still testing the app.
  2. SumitUpase24
    Donut Oct 19, 2020
    SumitUpase24 , via OnePlus 7T , Oct 19, 2020 :
    You can download the app from the above given link. I've downloaded the apk from the same link and even have different .xml settings for this. I can help you with that if you want.
  3. Viktor Ilie
    Froyo Oct 20, 2020
    Viktor Ilie , via OnePlus 7T , Oct 20, 2020 :
    Sure i want.
    The apk thing is ok, just dont know which version is best.
    About xml, that the thing i dont know how to make it work, neither i do know where to install it.
    If you have some tutorials , will be greatful.
  4. SumitUpase24
    Donut Oct 20, 2020
  5. SumitUpase24
    Donut Oct 20, 2020
    SumitUpase24 , via OnePlus 7T , Oct 20, 2020 :
    Once you create this folder open the GCAM app and then double tap the marked area to load the .XML file option
    If you have any .XML files please first save it in CONFIGS7 Folder we created in file manager. Once saved click on the area marked you'll see that .XML file over there and restore the data. And done you are ready to use the GCAM !!
  6. Viktor Ilie
    Froyo Oct 20, 2020
    Buddy thank you dor the tips and help.
    I did it, everything is fine except one thing, it restarts the camera app everytime I change from main camera to any other.
    By the way, google camer wide angle camera produces much better pictures.
    SumitUpase24 likes this.
  7. Viktor Ilie
    Froyo Oct 20, 2020
  8. SumitUpase24
    Donut Oct 20, 2020
  9. SumitUpase24
    Donut Oct 20, 2020
    Yes this also happens with me.
  10. Viktor Ilie
    Froyo Oct 20, 2020
    Nope, take a look, the below one is GCAM, and the table isnt very clear as it is on the 1st one.
  11. SumitUpase24
    Donut Oct 20, 2020
    I am not getting it. I said the 2nd pic is of GCAM
  12. Viktor Ilie
    Froyo Oct 20, 2020
  13. SumitUpase24
    Donut Oct 20, 2020
  14. bizzy43
    Cupcake Oct 24, 2020
    bizzy43 , Oct 24, 2020 :
    Hi,
    Trying to clarify that the Gcam port 7.3.018 limits resolution? I have the full resolution setting selected.
    If this is the case, is the trade off of losing resolution vs gcam functionality worth it?
  15. SumitUpase24
    Donut Oct 25, 2020
    SumitUpase24 , via OnePlus 7T , Oct 25, 2020 :
    Nope
  16. AMZATH91
    Cupcake Oct 25, 2020
  17. Michal C
    Cupcake Oct 29, 2020
    Michal C , Oct 29, 2020 :
    Hi Friends. I am buy new OP7T Pro and than install last version GCam Wichaya v2.9.1 with nRG OP7 config. When I switch from main camera to zoom lens and than back, Main lens do a physical move with "tick" sound noise.
    It's OK?
    I'm afraid the camera may be damaged.
    Original application runing normal without noise.
    Thank s
  18. Amal shyjo
    Eclair Nov 15, 2020
    Amal shyjo , Nov 15, 2020 :
    @tide1109
    https://www.celsoazevedo.com/files/android/google-camera/f/changelog1482/
    this is the port for the latest google cam v-8 which came with the Pixel 5 phones it's still in beta I guess but it works well and also provides the new video stabilization options.
    Version 6 based on google camera 8.0.101 only devices:
    1 : Oneplus8Pro, Oneplus7Pro, Oneplus7tPro, ZF6,Oneplus8T, OneplusNord, S20 Ultra, Poco x3, Redmi Note 7 Pro
    2 : Oneplus7, Mi9TPro, Mi 10 ultra, Mi Note 10 pro, Mi Note 10 lite, Mi 10, Redmi Note 9 Pro, Oppo Find x2 Pro, Realmex2pro
    3 : redfin Pixel5, bramble Pixel4a(5G), sunfish Pixel4a, coral Pixel4XL, flame Pixel4, bonito Pixel3aXL, sargo Pixel3a, crosshatch Pixel3XL, blueline Pixel3, taimen Pixel2XL, walleye Pixel2
    G_Denis_Yakovlev_ovdm likes this.
