3
[Submitted] Google Duo keeps crashing
  1. Soumyobrata
    Cupcake Aug 6, 2021
    Soumyobrata , Aug 6, 2021 :
    Hi,
    Bought my Nord 2 on the first sale. Everything is working fine however the Google Duo app in between video call keeps crashing. Tried WhatsApp video call as well. Same results. However the duo crash is much more persistent. Happens all the time between important calls. Tried all trouble shooting like restarting, reinstalling, cache clear and all, nothing changed. Any work around?
  2. Dipjyoti Nath
    OnePlus Bug Hunter Staff Member Aug 6, 2021
    Dipjyoti Nath , Aug 6, 2021 :
    We are sorry to hear that you have faced such an inconvenience with your device while operating it and thereby have contacted you through direct message to give you more insights regarding this. Please check for the same.
    Regards,
    Dipjyoti
    Sushmit M likes this.
  3. Sushmit M
    Cupcake Aug 24, 2021
    Sushmit M , Aug 24, 2021 :
    I am facing the very same issue on a Nord 2, do share any workarounds or fixes in relation to this.
  4. maartenflippo
    Cupcake Oct 26, 2021
    maartenflippo , Oct 26, 2021 :
    I just bought my Nord 2, and I have the same issue. I can start a call with Duo, but about 30s into the call Duo will freeze up and crash. I have not found any solutions to this. Things I found and have tried:
    • Install all updates
    • Buggy system webview (updated or removed update, I can't uninstall it)
    None of these have worked, but it seems the problem is exclusive to Duo but it works no problem on my OnePlus 5t (which I want to replace with the Nord 2) and they are on the same version of Duo. The difference is the version of OxygenOS: 10.0.1 on the 5t and 11.3 on the Nord 2.
    Looking through Logcat, it seems Duo is trying to request details about a camera that does not exist:
    Code:
    10-25 23:07:55.463 24344 24422 E AndroidRuntime: FATAL EXCEPTION: PeerConnection-3
    10-25 23:07:55.463 24344 24422 E AndroidRuntime: Process: com.google.android.apps.tachyon, PID: 24344
    10-25 23:07:55.463 24344 24422 E AndroidRuntime: java.lang.IllegalArgumentException: supportsCameraApi:2439: Unknown camera ID 0
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.hardware.camera2.CameraManager.throwAsPublicException(CameraManager.java:1054)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.hardware.camera2.CameraManager.getCameraCharacteristics(CameraManager.java:480)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at sel.h(PG:1)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at sel.f(PG:1)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at efx.y(Unknown Source:0)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at efx.k(PG:2)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at efm.run(PG:7)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.os.Handler.handleCallback(Handler.java:938)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.os.Handler.dispatchMessage(Handler.java:99)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.os.Looper.loop(Looper.java:264)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.os.HandlerThread.run(HandlerThread.java:67)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime: Caused by: android.os.ServiceSpecificException: supportsCameraApi:2439: Unknown camera ID 0 (code 3)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.os.Parcel.createExceptionOrNull(Parcel.java:2403)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.os.Parcel.createException(Parcel.java:2373)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.os.Parcel.readException(Parcel.java:2356)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.os.Parcel.readException(Parcel.java:2298)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.hardware.ICameraService$Stub$Proxy.supportsCameraApi(ICameraService.java:906)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.hardware.camera2.CameraManager.supportsCameraApiLocked(CameraManager.java:1107)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.hardware.camera2.CameraManager.supportsCamera2ApiLocked(CameraManager.java:1083)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     at android.hardware.camera2.CameraManager.getCameraCharacteristics(CameraManager.java:453)
    10-25 23:07:55.463 24344 24422 E AndroidRuntime:     ... 9 more
    I am unsure if this is the cause of the crash, but it is the only stacktrace I can find in Logcat.
  5. Sushmit M , via OnePlus Nord 2 Gray Sierra , Oct 28, 2021 :
    I really appreciate how you've taken the time out to try and locate the source. This is a long standing problem now, and I've even submitted logs with no effect. I really hope the Dev's check this out. Apps like Messenger and WhatsApp, while they don't freeze like Duo, they do randomly shut off the front camera for no reason. It's definitely a software end issue.
  6. mfhbrown
    Cupcake Nov 13, 2021
    mfhbrown , Nov 13, 2021 :
    Same issue here. Performed factory reset, still happening. Duo effectively unusable.
  7. #7
